LQ4/9 Block casting numbers?
Old Jun 7, 2009 | 11:19 PM
$O$OE's Avatar
Question LQ4/9 Block casting numbers?
Can some one post a link or let me know the casting numbers on the Lq4/9 block for 2001+ years. On the hunt for a LQ4/9 and dont want to buy the short block with the longer rear flange if I get the Lq4. So I need a casting number(s) for the 2001+blocks...Thanks
Old Jun 7, 2009 | 11:21 PM
$O$OE's Avatar
I also know you can tell the difference in the heads, Aluminum VS iron. But I dont want some1 saying its a 2001+motor because it has the 317 heads. anyone can swap the heads and say its a 01+motor.
Old Jun 8, 2009 | 07:39 AM
69LT1Bird's Avatar
http://www.mortec.com/castnum.htm
I don't think the block casting number will be different,it is primarily the crank and heads.
Old Jun 8, 2009 | 03:44 PM
$O$OE's Avatar
will I need a way to fin out if im buying a 2001+ motor because i dont want to get stuck with a 2000 or older motor and have the longer flange..because some people can slap some 317heads and tell me its a 2001+ motor and I wont be able to tell if im getting the one with the longer flange(which i dont want) or not
Old Jun 8, 2009 | 03:50 PM
NemeSS's Avatar
u can tell just by looking at the rear main seal/cover. if the flange sticks out about 1/2 in, its a 2000.
i prefer the long flange crank engines, the offset is correct to use a sbc trans, such as th350/400 without spacer.
Old Jun 8, 2009 | 03:56 PM
69LT1Bird's Avatar
If it has a flywheel and there is a spacer, it is a newer style.
Check this link for a couple of pics compared to a LS1.
http://www.thirdgen.org/techboard/lt...0-lq4-6-a.html
Old Jun 8, 2009 | 04:23 PM
$O$OE's Avatar
Ok Cool thanks for the info 69LT1Bird & NemeSS
Old Jun 8, 2009 | 05:51 PM
TT632's Avatar
Might have one of interest; https://ls1tech.com/forums/lsx-parts...ater-pump.html
