Oil Consumption LS2 427
This latest diagram shows ports on the valve covers that do not even exist, requires parts that did not come with the "complete" kit I received, and this diagram contradicts the diagram I received with my kit.
All of this makes me want to throw in the towel. :-(
A zillion different diagrams, showing a zillion different things, and having to drive all over town trying to track down parts...there must be something better.
Don't get frustrated, it's really easy. What engine do you have? What ports don't you have? What parts are missing?
I've updated the LS3 diagram, I had too many ports on the passenger valve cover.
The last picture posted is looking way better already!
The LS2 passenger valve cover does not have a port at the rear. It only has the port shown in the pic.
The LS2 driver valve cover does have a port, but from the factory the port is closed off (small rubber cap on it).
Top of RevXtreme catch can <--> valley cover port
Side of RevXtreme catch can <--> intake port
Passenger-side-valve-cover port <--> throttle body port
Replace aftermarket oil cap breather, with stock oil cap
Is the above correct?!
With the RevXtreme catch can installed, I am still consuming oil. :-(
Catch can was installed a few hundred miles ago. Fresh oil change and fresh spark plugs at the same time. I checked tonight and the dipstick reads a bit below the middle dot. When the oil change was done, the oil level was a hair above the top dot.
I also pulled a single plug (which was new), and it is now oily.
I opened the drain on the catch can and no oil came out.
Tomorrow I am hoping to remove the throttle body and check the intake for oil. When the catch can was installed the intake was cleaned at the same time. If oil is making it through the catch can, the intake should/would be dirty again.
With the baffel system, oil can't make it through the can....it is impossible. Lets go over the hose routing again. Outlet of the can (side fitting) goes to the intake manifold snout fitting (vacuum source), and the top fitting (inlet) goes to the crankcase outlet (valley cover vent or the valve cover fittings).
Should be no lines from the valve cover to the throttle body unless you are using it as your fresh-air source and then oil could be entering through the throttle body. If your plugs show oil it is entering the combustion chamber. Only way for that is:
1. poor ring seal allowing oil past on the intake stroke into the combustion chamber.
2. oil being pulled into the intake from the PCV system (the most common with modern engines)
3. oil being pulled past the valve seals & through the guides on the intake stroke.
Any of these can and will push oil into the intake runners through reversion pulses at high rpm's making it difficult to diagnose, but no matter what with any of the above problems the catch can if it has a vaccum source pulling correctly it will accumulate some oil, so I suspect there is an issue in the routing somewhere.....
Before the RevXtreme catch can, when I pulled the plugs they were all fouled and all fouled the same amount. Does that provide any insight? I.e. would it be unlikely that all of the valve seals were bad, and "bad" the same amount, to foul the plugs equally?
The specs of the setup are:
LS3 Aluminum, 6 Bolt Main, 4.067" Bore
Manley forged dish pistons 4.065", -2cc
Callies CompStar 4.00" stroke, forged crank
Callies CompStar forged Connecting H beam Rods, 6.125" length, 2.100" crank pin, .927 wrist pin, (Includes ARP 2000 Series Connecting Rod Bolts).
L92 heads, milled 0.030, 65 CC chamber
LS3 GM MLS 0.051" gasket, bore diameter 4.100"
Comp 921 spring kit
Comp Cam 230 XFI / 242 XER, 114 LSA
Ported LS3 intake
Manley hardened 7.35" pushrods
Ackerly & Childs NOS/Boost rings 1/16 - 1/16 - 3/16
Clevite "H" series race rod and main bearings
Durabond cam bearings
PowerBond underdrive pulley
Monster flywheel and Stage 3 clutch
LG Pro Longtube headers (hi-flow cats)
Corsa Xtreme catback
DTE Stage 1, 4.10 rear diff
Vararam
Tuned with HP Tuners VCM Suite
Blue line --> Valley cover port to top port on RevXtreme catch can
Purple line --> Intake manifold port to side port on RevXtreme catch can
The connection that confuses me is the "Red line". Would the Red line not circumnavigate the entire catch can setup? With the throttle body open, a vacuum would be created and any "oil mist" would be drawn from the passenger valve cover into the throttle body?
If the next troubleshooting step would be to put the Cartek catch can back on (and measure the results), I can certainly do that.
The top fitting needs to connect to the vally cover fitting.
Although it is hard to tell in the picture above, I have also verified the following:
- The "blue" line (on the top of the RevXtreme catch can) connects to the metal port on the valley cover.
- The "purple" line (on the side of the RevXtreme catch can) connects to plastic port on the manifold intake.
Tracy, following what you stated above, I should:
- Remove the "red" line/hose.
- Cap the port (on the valve cover) that the "red" line was connected to.
- Cap the port (just before the throttle body) that the "red" line was connected to.
- Replace the stock oil cap, with an oil cap breather.
Do I have the above correct?
Jackson
