(l92)aftermarket cam help
Old Jun 23, 2009 | 11:26 AM
chacho44's Avatar
Default (l92)aftermarket cam help
Any advise on a cam for me cant do much do to limited funds, but this is what i got... 2008 l92 bone stock just gonna do some long tubes and other lil things but def wanna ddrop in a cam and i would like to drop in something radical sounding that can give me sweet gains and sounds sweet and thats what im lookin for. All advise will be appreciated. I already purchased the cc gen iv ls vvt 275phr-14, at $456 or something.. I was told it wont sond that radical just a good idle lump sound, i would love to drop in something radical but not sure what i can do. If i can get something like i want ill need to sell this cc model. Im new to these motors and to motownmuscle, so if you can help out it will be great. Thanks
Old Jun 23, 2009 | 05:31 PM
FaSSt9602's Avatar
You got the largest of the VVT cams from Comp. Being that I have never heard the VVT cammed, I am not sure if it will calm it down at idle, but in a "normal" car, that sized cam would be noticeable, but not crazy. If you plan on keeping the VVT, that might be about as big as you can go otherwise you run into valve to piston clearance issues when timing is constantly changing. If you want to ditch the VVT, you could put a cam in it so big that it would shake the doors off...either way, you are going to need new valve springs.
Old Jun 23, 2009 | 07:51 PM
chacho44's Avatar
What is the meaning of the vvt, and dod.
Old Jun 23, 2009 | 08:05 PM
ajw2500hd's Avatar
lg g6x3
Old Jun 25, 2009 | 11:24 PM
chacho44's Avatar
Originally Posted by ajw2500hd
lg g6x3
Old Jun 25, 2009 | 11:26 PM
chacho44's Avatar
Longtubes, frame, and motor mounts on there way. Should be here in couple days
Old Jun 25, 2009 | 11:55 PM
FaSSt9602's Avatar
VVT = Variable Valve Timing and basically the valve timing is constantly changing throughout the RPM range.
DOD = Displacement On Demand - The computer basically shuts down 4 cylinders to be more fuel efficient but directing oil to, or away from the intake lifter. You may or may not have this. Is the area under your intake manifold smooth or have a bunch of bumps all over it?
Like I told you in a PM, the wiring harness is going to be your biggest hurdle. The motor mounts and headers are the easy part!
Old Jun 26, 2009 | 08:53 AM
Gen414's Avatar
Originally Posted by chacho44
Im with you...hahaha
Old Jun 26, 2009 | 09:57 AM
ajw2500hd's Avatar
Lg motorsports g6x3 cam is a badass cam!!!!! IF YOU TAKE OF THE VVT ITS JUST A VALVE COVER AND SOMEOTHER STUF!! IT WILL BE WORTH IT!
Old Jun 26, 2009 | 11:44 AM
chacho44's Avatar
Old Jun 26, 2009 | 11:45 AM
chacho44's Avatar
ahhhh now your speakin my language
Old Jun 26, 2009 | 12:48 PM
hookemdevils22's Avatar
g6x3 installed in an LS3 corvette. this will give you an idea of the g6x3 in an L92.
Old Jun 26, 2009 | 02:19 PM
chacho44's Avatar
HOLY FRIJOLES IM IN LOVE,
Old Jun 26, 2009 | 04:02 PM
chacho44's Avatar
Anyone have the parts ill need to loose my vvt layin around???
Also can you please list them exactly so i can check myself. Also if i do this should i loose the dod as well???????????
