Cam and heads question!
Old Jun 27, 2009 | 07:46 PM
JoshuaCole67's Avatar
Default Cam and heads question!
Ok i am finally gonna cam my car... most of my friends have a MS4 cam and ls6 P&P heads... well i dont wanna go as agressive as an ms4 cam but i want people to know that i am cammed... i drive i drive 52 miles round trip to work until i can get another daily driver... i have an ls6 intake and paceseter longube headers.. wat cam is best for me? and i dont wanna spend a *** ton of money on heads so im just goona get mine cleaned and ported and polished... Good idea? i drive a 2000 camaro Z28 M6...
Old Jun 27, 2009 | 07:52 PM
ShoddyHog's Avatar
StreetSweeper-HT. Nice lope. Sounds great. Torque all over. 228/232 .612/600 111 With a good tune, will drive almost exactly like stock.
Gerry
Old Jun 27, 2009 | 08:20 PM
ok.. how much hp id you gain? wat rockers, spring and pushrods did you find most effective with that cam...
Old Jun 28, 2009 | 09:10 AM
ShoddyHog's Avatar
I gained about 40 on my LS2 - I'd recommend the whole kit...last one on the list http://www.flowtechinduction.com/packages.htm
Gerry
Old Jun 28, 2009 | 10:07 AM
Gen414's Avatar
With these motors, you can make aboat load of power, and still get 20+ MPG, keep that in mind (even with a big cam). What I would do is look for a nice set of stock heads (since you said you wanted your stock heads ported) like the 243, have them ported and cleaned up like you want (that way, you have the heads ready to go whenyou tear the motor down ). Because if you tear it down, and THEN send your heads off, you could be without your car for a couple/few weeks while your guy ports your heads
You are gonna be looking for something in the 22x/23x range @ .050 with high .500/low .600 on a 112 LSA. Now, you go with a narrower LSA, like a 110, that is where you are gonna get alot of your "lope" from. but also keep in mind, that cam is probaly not gonna make the BEST AVG power for you, but it will give you teh sound you are looking for, keep that in mind.
Also, keep in mind that the lower you can keep teh lift on teh cam, the more reliability you will have with stock rockers (if you so choose to run them) I know some guys have run mid .600 with success, but the stock rocker was not meant for that, and you will get alot of wear on valve guides and even damage to the tips of your valves. And, the Lift on teh cam has basically no say in how the cam "sounds". It is more in the duration and LSA. So, if you are looking more for reliability, go with a mid .550-.600 lift cam, but of course, if you are gonna run aftermarket rockers, then pretty much whatever you want, for teh most part.
Old Jun 29, 2009 | 08:30 PM
wow that was alot of helpful info... everything you mentioned is wat i am wanting.. if i do do a cam i am gonna upgrade my rockers, pushrods and springs just to freshen the engine up a bit... .550-.600 will give me the best "lope" while gaining some hp to the wheels and keeping reialbility cuz y car is my dd... ? am i on the right track so far? should i upgrade andthing else while i have it torn down?
Old Jun 29, 2009 | 08:34 PM
Gerry
i went and looked at the cam and everything but it sas its for an ls2 engine and i am a ls1? can i sill run this cam.?
Old Jun 29, 2009 | 08:51 PM
Gen414's Avatar
Well, you kind of misunderstood me, or maybe I was not clear. What I said (or meant) was that the lift of the cam is NOT gonna give you the "sound" you are wanting. You get the "sound" or "lope" from duration and LSA (valve overlap).
Since you are upgrading to a full roller rocker, you can get by with more lift and not worry about wearing out stuff like you would with stock rockers.
Well, since you are replacing the cam, change out teh timing chain, and even the oil pump. On the oil pump, it is still good if you have good oil pressure, but you may have alot of miles on it, and for the money, and since you are there, something to think about anyways (even though you don't have to pull off the oil pump to change out the cam, or teh timing chain for that matter)
Old Jun 29, 2009 | 11:48 PM
im sorry.. i did read that i just typed it without thinking.. lol.. u said it clearly.. lol... i was planning on doin my oil pump anyways... but i am gonna do all this stuff at once so i dont gotta worry about it later on down the road...
Old Jun 30, 2009 | 08:00 PM
ShoddyHog's Avatar
Yes, there are a few GTOs running that cam in a LS1, and I have yet to see anyone not love it.
Here's what it sounds like in a LS2
http://www.youtube.com/watch?v=aORkvjwg0ok
LS1:
http://www.youtube.com/watch?v=uyptjQDE_gY
Gerry
