Forged Piston Recommendations???
You also need to have nice straight and round bores with the right finish on them for the rings you will be using. This is not something the normal guy can even inspect so you need to use a real machine shop that does real engines and has the appropriate tq. plates and the right hone and stones or diamonds etc.
You need to know everything about the engine including the real duty you will be subjecting the pistons to. Piston speed is a non issue but the important things are fairly complicated so you need to know a lot more than the average piston tech will ask you since they usually don't really give a damn. Been there done that 1 million times.
I've been fixing crap thrown out by big piston companies for years. You can get a great piston from company XYZ if you go through one guy there and yet a POS from another guy there just by how they put your order in so be wary and only order a custom piston from someone that knows WTF they are doing.
Shelf pistons I think Wiseco and Diamond have the biggest selection and understand the LS1 best at this point. In addition shelf Wiseco's have skirt coatings and anti detonation grooves on the top land and a pressure accumulator groove on the second ring land and feature double pin oilers and an inboard pin boss design as standard which clears the block and reluctor very well on 99 percent of builds.
I order custom pistons for several shops and of course on all our own builds and have decided to start doing more customs if people want to go through us for Wiseco or Diamond. I can only be reached by email 99 percent of the time and then I can call customers back but we are too busy to answer the 4 phone lines we have on a regular basis unfortunately plus calling is BS untill you know what you really want.
I have my own piston build sheet form and having done about 1000 sets of custom pistons that we used oursleves aver the last decade I have a small idea of what works. Keep in mind though that pistons ARE compromises sometimes so you have to realize you can't just do anything with any piston.
! Thanks.
The accumulator groove on the second land increases the volume under the top ring and above the 2nd ring so the top ring doesn't unseat as much. The top ring is held down and out by gas pressure differential and of the space under the top ring fills up and equalizes then the top ring doesn't seal very well. You also want a larger 2nd ring gap for this reason. Another quote from various sources : "The accumulation of gases that get by the top ring can unseat it. A pressure groove delays this action. This is why today's recommendation is to keep the 2nd ring end-gap as large as or larger than the top ring end-gap. It is a shaped channel that works by equalizing the pressure seen between the top and second ring with the pressure in the combustion chamber. This feature enhances ring seal, improving power, and engine life and fuel economy. The presence of this feature depends on your piston manufacturer as some have them, some don’t."
The thin grooves above the top ring are the anti-detonation grooves and the single large groove is the accumulator groove in the second ring land.
Also the Diamond and the Wisecos are usually supplied as pass and driver sides with offset to keep them quite in street engines when they are cold.
Also aren’t there two different forged aluminum alloys, one being stronger and softer but wears faster then the other?
one is 2618 aluminum alloy and the other on is 4030 ?
i have wiesco 2618
That might have been the reason behind my offset being zero, again they can be heard until it is all up to operating temp. I think the extra clearence due to the alloy mixed with the short skert design contribut the this as well. I almost went with a custom set of Wiesco pistons, but all I knew of them was in dirt bike pistons (this area the are king in).
Do you find the offset Wisecos and Diamonds are dead quiet on cold start with abuse type P to B clearances?
Interestingly enough we have never even had a qyestion about piston slap or noise on the Wiseco and Diamond stuff with offset ever so far in 7 years so it has got to be a substantial difference seeing that we have done over 1000 of these engines and it blows my mind that I have never heard a single complaint.
I would still expect at least a little noise though especially with the bigger clearance stuff even with offset though to answer your last question like when we specifically put in more cold clearance for a bigger power adder deal etc. There has to be more noise I would think but I guess not enough to freak people out a lot at least so far?
On the stroght pin no offset deals with really big clearances people actually do worry and think they have a diesel untill the engine is pretty hot. I think it depends on your exhaust and what other noises you have to distract yourself probably. My old mustang with no offset Manleys and some bigger clearance was pretty loud until the engine was hot.
People even would tell me at races to turn it off and check the oil since my engine was knocking! Hahahahaha.
