LQ9 to L92 Head Gaskets
Old Sep 10, 2009 | 02:12 AM
frankmarroquin's Avatar
Default LQ9 to L92 Head Gaskets
Hey guys, well my question is does anyone know the part number of gasket that I would need because I purchased L92 heads for my GenIII LQ9 6.0. I read that they have to be 4.065 sized gaskets. I got this part #12610046 but dunno if its the right one. All help appreciated...
Old Sep 10, 2009 | 06:48 AM
SweetS10V8's Avatar
I just swapped L92 heads on my LQ9 and #12610046 is the correct number to use.
Old Sep 10, 2009 | 09:18 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
^x2
and we have them readily available in either GM or cometic
Old Sep 10, 2009 | 09:50 AM
68 RS Convertible's Avatar
I used the L92 6.2L head gaskets for my 6.0 build, but my block is .030 over. I thing the p/n was 12610046.
Old Sep 10, 2009 | 09:57 AM
the_merv's Avatar
Veteran: Air Force
I plan on using the Felpro 1041's for my 408..
Old Sep 10, 2009 | 10:02 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
4.135 bore does seem a bit much on a 408 but that is just my .02
Old Sep 11, 2009 | 04:34 AM
Thanks guys for the quick responses...
Old Sep 11, 2009 | 10:29 AM
tripblackls1's Avatar
i use felpro 1041s on my 346 and they work just fine
so i think 408 would be as well
Old Sep 11, 2009 | 10:31 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
im not saying they will not work. but when you are trying to hit a certain CR, they are kind of like working backwards to the cause
Old Sep 11, 2009 | 10:33 AM
umm?
explain?
Old Sep 11, 2009 | 10:39 AM
the_merv's Avatar
Veteran: Air Force
Basically you are trying to up the Compression with a thinner Gasket, but with the bigger Bore of the Gasket there is still that open area and it doesn't really help in a way..
It's like taking a thicker Gasket and smushing it..it's thinner but the Bore is bigger so you really aren't getting rid of that Compression area that is there.
Thinner Gasket with the small Bore would be ideal.
Old Sep 11, 2009 | 10:41 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
because the bore is so large, the area that the gasket makes will contribute to compression ratio. idk why you would use a bore size so large on the gasket for such a small bore. there are other gaskets out there that are better suited.
Old Sep 11, 2009 | 10:53 AM
interesting i never realized that bore size of the gasket attributed to cr,
i guess because of my ignorance i could have made a better gasket choice
second question(sorry for the hijack)
how does it affect the quench area?? would it be benefit to run a larger bore gasket to increase the quench but not raise the compression so much??
Old Sep 11, 2009 | 11:02 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
quench is a touchy subject lol
Old Sep 11, 2009 | 11:03 AM
the_merv's Avatar
Veteran: Air Force
The size of the Gasket Bore does affect the CR..you can run a thinner Gasket with a bigger Bore to not make it as high compared to if it would have a smaller Bore.
Old Sep 11, 2009 | 11:26 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
it may not make a huge diff as in a whole point, but it is a factor
Old Sep 14, 2009 | 11:16 PM
Is it posible to run the MLS 6.0 headgaskets for the L92 heads.
Old Sep 14, 2009 | 11:33 PM
the_merv's Avatar
Veteran: Air Force
You will need atleast a 4.085" Bore Gasket to take full atvantage of the L92's..I think the stock 6.0l MLS Gasket is smaller than that.
Old Sep 15, 2009 | 12:55 AM
True that, Thanks I already ordered the ones needed....
Old Sep 19, 2009 | 04:32 PM
Quick questions SWEETS10V8 since you did basically the same swap... What lifter trays did you use Stock Lq9 or other ones? I already ordered the 6.2 MLS Headgaskets, 8 Offset Rockers, L92 Heads, LS3 Intake, 92mm Cable driven TB. What else is needed or am I missing? Thanks all appreciated
