Foundry location for GMPP - LSX block???
Kurt
Ok guys, I have asked for some updates and permission to answer some of the questions here. As you know things such as suppliers or sources are off limits. I can understand the reasons.
I asked how to address a vendor change with regard to the LSX block and I got this response.
"The latest LSX block is not so much about "new" features, as it is about maintaining a constant supply of high-quality blocks. The GEN I LSX block was cast in a GM production foundry overseas. This foundry was excellent in producing aluminum LS blocks, but turned out to be not as good at producing the LSX cast iron block to the GMPP Bowtie standards. After struggling with supply interruptions for over a year, it was determined that the only way to cure the problem was to move production. As a result, the "new" LSX blocks are now poured in the same foundry that produces the Bowtie Big Blocks for GMPP, right here in the USA. The GMPP engineering standards and validation process is much more stringent than anyone else in the aftermarket. By working with our foundry close to home, we can maintain a constant dialogue, as well as more closely monitor the casting process at every step of the way. It's real simple: If you start with a less-than-perfect casting, you're not going to be able to machine a finished product to the standards that GMPP designs and our customers expect.
We are confident that these changes, although painfully slow, will guarantee that LSX Bowtie blocks are available daily on demand for years to come."
After reading that I felt as though I could not have said it any better.
The key to control the quality that we deliver to the customer.
Thanks
Robin
P.S. as soon as I get any updates on supply I will let you know. But I will call John at SDPC first.
That spec was changed a while ago. All is good.
Many people have preferences for different parts. I like the dura bond cam bearings myself. If you don't like the bearings then have your builder change them.
If you have a specific issue with the machining please send me a PM and I will address it with the engineers at GMPP.
The blocks are machined at the same facility that machined the gen 1 LSX blocks.
Robin
The cam bearings are up to the builder. The bearings that come with the block are tongue and groove type, they are very strong and will carry high loads but a pita to install with conventional cam bearing tools you will find in your local machine shop. This is compounded by the LSX tunnel being a bit on the tight side in some cases. I personally use a tubular bearing in most builds, they are just easier to work with.
Kurt
Don't worry about me and my choice of machinists. My first little LS motor has been running now for two years, several thousand miles and plenty 10.30-10.50 passes N/A. And amazingly enough I assembled it just like every other engine I have built.
Keep in mind when you begin to talk down to someone or refer to them in a derogatory manner, your screen name is a representation of your employer.
And FYI, "faith on solid footing" is a contradiction of terms.
I have seen build where the shop has ignored the warnings from customers about the expansion characteristics of the aluminum blocks
While I have many things to say about the LSX block I could be percieved as biased. I appreciate Kurt, Erik and others candid comments about the LSX block.
Sometimes it is easy to read something into a post that isn't there. I have done this myself from time to time.
John has been around the block and I have never known him to talk down to anyone.
Hopefully we have answered your original question to your satisfaction.
Good luck with your project!
Robin
I meant neither you, nor anyone else to feel put down by what I said.
I think I am switching to Ford..
(This is aimed at no-one on here)
You want good news, stay off the interenet. You want to hear bad news...stay on.
