LS7 427 vs 440 question
Old Oct 17, 2009 | 02:10 PM
  #81
LS6427's Avatar
Originally Posted by Engine_HP
nice thread,
how much rwhp gain going from 427 to 440 ?
my guess would be no more than 10-15 rwhp.
I think a general rule of thumb, all else being equal and considering the extra cubes can breath, you gain about 1.5 hp per cubic inch.
But there are people, on this site, with big *** engines.....that have a top end that doesn't match and they make just a little bit more HP than engines with 50+ less cubic inches.
Old Oct 18, 2009 | 04:01 AM
  #82
Jessfly1's Avatar
Buy an LSX block and you can make it whatever you want without any problems.
Old Oct 18, 2009 | 04:37 AM
  #83
ramairws6's Avatar
Yep and add 125+ lbs. to the worst part of your car to add to...............
Old Oct 18, 2009 | 07:47 AM
  #84
99blancoSS's Avatar
125#'s isn't a big deal when you making 600-2000 rwhp. You can help to offset that as well. Most guys don't care unless they have a Vette and autox all the time. I haven't heard a complaint yet about the added nose weight, most of our customers say they don't notice any difference at all in the handling... just the neck snapping power
Old Oct 18, 2009 | 02:26 PM
  #85
LS6427's Avatar
This subject about the "extra" weight is really kind of OLD. Unless you're a competition road racer or a professional competition drag racer...its meaningless. And as mentioned, it HELPS keep the front end of the car down for drag racing.
Its just something poeple like to always bring up as a negative thing to say about using the LSX iron block.
Read the link below: The two fastest 1/4 mile LSx cars out there. Page #2, post #21.
He explains how the extra weight is a POSITIVE, and using the iron block he gets the added safety and reliability.
What do you think the extra weight of the iron block is slowing him down....maybe .02 seconds in the 1/4 mile. The more power you make the smaller the effect that extra weight has on ET. I'd rather be able to make a bunch more reliable power with an iron block to make up for that extra weight....then have to run an aluminum blocked engine near the ragged edge to compete.
https://ls1tech.com/forums/forced-in...s-warhawk.html
Old Oct 18, 2009 | 08:35 PM
  #86
cbr600rx7's Avatar
So could a forged 440 LS7 with 12.0 to 1 CR, mild cam, ported LS7 heads, be a good NA combo for 93 octane to make 600 RWHP?
Old Oct 18, 2009 | 11:55 PM
  #87
LS6427's Avatar
and a ported LS7 intake
A4...close
M6...for sure
There's a bunch of 427's over 600 RWHP like that witgh less compression, it would be a little easier with a 440ci.
Old Oct 19, 2009 | 06:20 PM
  #88
cbr600rx7's Avatar
So my next question is going to be is 12 to 1 going to be too much on a 440 LS7. I understand a lot comes down to the tuning but is that CR safe just for NA use.
Old Oct 19, 2009 | 07:11 PM
  #89
racer7088's Avatar
In many of not most areas if the country that is too much from what we have seen. You have to start pulling timing and any bad gas or really hot weather and you performance is substandard. You will make better dyno numbers on a cold engine though for sure.
Old Oct 19, 2009 | 07:41 PM
  #90
1.8t's Avatar
^ Any reccomendations on max compression for an NA ls7? ~11.5ish?
Old Oct 20, 2009 | 10:07 AM
  #91
racer7088's Avatar
Arrow
I'm not saying the other guys are dead wrong but we couldn't run that much compression.
I usually run about 11.25 but have run as high as 11.5 on some much bigger cam racier stuff that isn't a daily driver or going to sit baking in ruch hour traffic.
Old Oct 21, 2009 | 07:00 PM
  #92
cbr600rx7's Avatar
Ok i am very comfused now . I see some guys that claim they are running 12 to on street driven cars then i talk to some guys that tell me 11.5 is the limit. I dont see much driving above 3000 Ft and 90% of the time the car is is lower then 1000 Ft. NC gets gets up in the 90s in the summer but thats about as bad as it gets. I dont plan to put more then 3000 miles on this engine a year but i would like it to last at least a few.
Old Oct 21, 2009 | 09:32 PM
  #93
LS6427's Avatar
Mine is 11.3:1 and its a dream as a daily driver. Never know it was a built engine, unless you hit the pedal too hard. Never detonates down here on 100+* days either.
Old Oct 21, 2009 | 10:11 PM
  #94
racer7088's Avatar
It's up to you. I am not saying it will instantly explode or anything but you are pushing the pump gas thing big time.
Old Oct 22, 2009 | 12:34 AM
  #95
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default Pump gas compression ratio
Erik,
You are 100% correct on the ratio. The LS7 blocks I get in here with cracked walls all pushed the limit to 12:1 or more. Better be safe than sorry with the crap gas available today. You would be hard pressed to notice a half point difference on a street car regardless.
Back in the old days, before most of you guys were born, I used to run 12.5:1 on the street. That was when Sunoco 260 was available at the local gas stations back East.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Oct 22, 2009 | 05:54 AM
  #96
cbr600rx7's Avatar
Thanks for the help. Has any one out there broken the 600whp mark on a A4 car on a all motor LS7.
Old Oct 22, 2009 | 08:24 AM
  #97
Gordon0652's Avatar
Most likely...
I will be using a rather large cam and very nice intake and looking for a minimum of 640rwhp N/A.
Old Oct 22, 2009 | 09:28 AM
  #98
Stage7's Avatar
Originally Posted by Gordon0652
Most likely...
On pump gas? Those are lofty goals, I hope you reach them. What heads/cam/intake/TB are you using?
I love how the ceiling keeps being pushed with these NA builds despite suspect gas, while still having the ability to be reliable. Who would have thought 9yrs ago, 575rwhp out of a NA/LS motor would fairly common.
Old Oct 22, 2009 | 09:35 AM
  #99
racer7088's Avatar
Already been done with cathedral port stuff. Just depends on how wild you can go and if you have a lockup converter.
Old Oct 22, 2009 | 11:15 AM
  #100
Stang's Bane's Avatar
As far as the 12:1 compression issue. Just because you can go 12:1 doesn't mean that you should. I think most people miss that.
Sure, you can bleed off some presure with the right cam, but by doing so, you wouldn't really be running an optimized setup. JMHO
