LS7 427 vs 440 question
I don't really know how much anything costs to get built, if I could use anything off my current engine (LS6) to save money that would be nice too.
Would prefer a bigger cube engine since there "is no replacement for displacement."
I guess I would want something that could handle over 900 hp if I pulled down my supercharger, but would probably only keep it around 800 for fear of breaking other parts before I could afford to replace them. Lol
So resleeving with the ductile sleeves will totally eliminate that cracking issue with a 200 shot 440ci?
I was talking to Steve awhile back and IIRC...he said a resleeved LS2 was stronger than the LS7, but I forgot why. I think the main caps were steel in the LS2, is that right?
Erik- Approx how much is it to resleeve an LS7 block? This is safe to handle a 200-350hp nitrous shot then?
The LS7 block has doweled steel main caps where the LS2, LS3 - L92 have powdered metal main caps. I have several of my LS2 blocks making over a thousand to the wheels using the stock main caps - ARP studs with the Darton dry liners. The dry liners Darton makes are the same part number for LS2 LS3 or LS7 by the way. I'm just finishing decking an LS7 dry as I write this and doing an LS2 dry for an off road race engine tomorrow.
Cost of installing dry liners is considerably less than $2,400 as ERL stated. Wet MID liner is a bit more but will take a lot more abuse and the cylinders will stay rounder than any dry liner block, factory, resleeved, or after market.
As Erik said, I would not try to run 12:1 compression ratio in an LS7 with the stock sleeves, especially with nitrous. The sleeves and block behind the sleeve will split with the slightest detonation. I get a couple of LS7 blocks in a month to weld and sleeve.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve
So regardless what you build using a resleeved LS2 or LS7...as long as you stay N/A on pump gas...its gonna be seriously strong. 200-250 shot shouldn't be a problem either, right?
((but the LS2 will be a little stronger))
Is there a certain power level where LS7 blocks start to have issues regardless of N/A vs power adder?
My builder says I can (and will) spray this with a 150 shot plate, no problem, 225 shot direct port if I choose to go that way, no more than that he says with the LS7 block.
