Fu*k Trees!
Old Oct 11, 2009 | 02:36 PM
white2001formula's Avatar
Default Fu*k Trees!
I was removing my Intake manifold to change my Port Gaskets, and a fricken leaf falls into one of the head ports. I am at a loss for what to do. I've tried the vacume, and a long screwdriver. It's in the 3rd from the front port, so I can't even get my eyes far enough back to look into it the Head.
Is this going to be a Head pull?
-Chris
Old Oct 11, 2009 | 02:48 PM
SteelmanLS1's Avatar
Damn man I'm not sure what your going to have to do. That's about as bad as it gets.
If it makes you feel better I got a new rule in my rule book.
Rule 33. Don't work on cars under trees.
Old Oct 11, 2009 | 02:58 PM
therobman's Avatar
shop vac if u can get it out run it its a leaf
Old Oct 11, 2009 | 02:59 PM
tripblackls1's Avatar
is that vavle closed ???
if its is just take a air hose and spray compressed air into that cylinder and it should blow it out
but make sure to cover the rest of the intake ports when you do this
loyolacub68's Avatar
Its just a leaf, seems like this problem would take care of itself if you just run it. Not like a nut or something that is going to fall in and cause all sorts of damage.
Old Oct 11, 2009 | 03:00 PM
therealthatguy's Avatar
well thats an interesting situation, was it a dead leaf or a green one?
Old Oct 11, 2009 | 03:13 PM
luigiandme's Avatar
valve open? small enough leaf to have fallen in the chamber? Take out the plug and blow air in.
Old Oct 11, 2009 | 03:23 PM
wheels 2's Avatar
If the valve is closed you could spray something flammable in there and burn it out.Just not to much to blow **** up.
Old Oct 11, 2009 | 03:39 PM
I didn't even think about pulling the plug. I will try that. It was an old dead crispy leaf. I'm sure it won't cause any catastrophical damage, but I just want it out.
I just got back from sears...let's dance Leaf....
Old Oct 11, 2009 | 03:56 PM
00Silv4.8's Avatar
waste of money. If the valve is closed run it. Its a leaf, its gonna burn up and fire out the exhaust the second it starts.
Old Oct 11, 2009 | 04:32 PM
I agree, besides the leaf won that battle. I'm letting nature take it's course on this one.
Thanks,
Chris
P.S. **** Trees!
Old Oct 11, 2009 | 08:52 PM
Wnts2Go10O's Avatar
its a leaf... not a nut/bolt
Old Oct 11, 2009 | 09:01 PM
elias_799's Avatar
lol, wtf is the condition of the leaf have anything to do with it.
if you can't blow it out, you should be able too but if you can't just run it and then replace the spark plug on that cylinder just to be safe.
Old Oct 12, 2009 | 06:57 AM
Busted Knuckles's Avatar
I saw an old 350 suck a red shop towel thru an intake and spit pieces out the header. It missed a couple of licks but ran fine after. Don't worry about a leaf, it's not an issue.
So, are you a true "shade tree mechanic"?
Old Oct 12, 2009 | 10:02 PM
I guess that's my new title...Mods, please change.
Old Oct 13, 2009 | 12:15 AM
JDMC5's Avatar
dude its a leaf, you're fine.
Old Oct 13, 2009 | 12:33 AM
airfix's Avatar
**** Trees I climb Bouys ************.
Old Oct 13, 2009 | 12:55 AM
ls1ya's Avatar
either blow air or fire her up
Old Oct 13, 2009 | 01:32 AM
seemed like a reasonable question.
Old Oct 13, 2009 | 03:51 AM
tektrans's Avatar
You're fine with the leaf!
Bad news is when you went to buy the vaccum kit, a squirrel buried a bunch of nuts in the other ports, hehe
