L92 Head?
Old Oct 20, 2009 | 07:17 PM
flatchat's Avatar
Originally Posted by 1CAMWNDR
I assume you mean the price reflects the flow and power potential. Yes it does. It is meant to be a race piece to bridge the gap between the mass produced intakes from GMPP and Edelbrock and a custom sheet metal intake. Think @$1200 complete with CNC work. Check with Cary for specifics.
Try $2200 . Im just waiting for mine to be finished which will be matched to some MAST med -bore LS3 heads which will be going onto a solid roller 408
Old Oct 20, 2009 | 07:20 PM
Rock_Daddy's Avatar
Yep not cheap but you know what. I'd buy it again.
Old Oct 21, 2009 | 09:32 AM
1CAMWNDR's Avatar
Woops. Still, if you need it, it beats the **** out of $3500+ for a sheetmetal intake.
Old Oct 21, 2009 | 10:51 PM
NBM99SS's Avatar
Originally Posted by Rock_Daddy
Im running stock L92's (aftermarket springs) going through the traps at about 7200rpm 9.48@141.05
61 runs so far and no issues.
Good to know. I think I will be ok then
Old Oct 23, 2009 | 08:45 AM
Jim85IROC's Avatar
Here's a similar question. I'm assuming that with the LS3 hollow valves you can run less spring than you need with the L92 valves. Is there any drawback to the added spring pressure? If the car has upgraded pushrods and has the harland sharp mods to the rockers, there's really no issue is there?
Old Oct 23, 2009 | 11:10 AM
ss.slp.ls1's Avatar
I had a buddy put thousands of miles on his engine with PRC .660" dual springs. Both with a MS3 cam and then back to a stock cam and keep the springs. No issues.
Old Oct 23, 2009 | 05:28 PM
rsz288's Avatar
GM uses the lightest springs they can to minimise friction, that can that satisfy valvetrain control & durability requirements.
