LS2 into 2000 T/A
If the engine is on the stand, why don't you just look? Take the oil pan off (you've got to anyway to put your F body pan on) and count the teeth on the reluctor wheel. It is at the tail end of the crank. Use a sharpie to mark where you started.
Unless somebody that really knows chimes in here, I'm almost POSITIVE that the 05 GTO LS2s were 24-tooth, and the 06 GTO LS2s were 58-tooth. I KNOW that my 05 GTO LS2 is a 24-tooth, though.
