VVT swap oil system questions
1 Post
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Hey guys,
I'm getting considerably closer to having my L92/T56 drivetrain swap completed in my GTA, & I've just started questioning a couple of things - I'm hopeful that someone here can chime in with answers...
First off, since the L92 is a truck engine, am I creating a potential problem by swapping to the F-body oil pan? I don't recall the capacity for each pan off the top of my head, but I do recall hearing of drain-back issues with LS-series engines, where high RPMs can pull the pan dry... I'm hoping to occasionally take part in some road-race/open-road events, so this question isn't entirely theoretical.
Second - what is the "typical" oil pressure in a VVT engine? I know that it's considerably higher than in a "normal" engine, but I don't think I've seen a value for it. I've just purchased a mechanical Auto Meter 0-150 psi gauge to monitor it, so I'd like to know the normal range to watch for.
Finally, I've upgraded from the plastic to the copper line for that gauge - anyone happen to know the burst rating for that line? I would think that Auto Meter wouldn't offer a mechanical gauge unless the feed line to it was able to handle the full rated pressure of the gauge, but hell, I've been wrong before...![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Thanks guys, any hard/definite info is much appreciated. Second - what is the "typical" oil pressure in a VVT engine? I know that it's considerably higher than in a "normal" engine, but I don't think I've seen a value for it. I've just purchased a mechanical Auto Meter 0-150 psi gauge to monitor it, so I'd like to know the normal range to watch for.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
