LSA Pistons vs LS9 Piston facts: + Pics
Back on topic.
LSA rod. The rod itself weighs 696 with bolts included. Has tapered small end with the bushing of course. The bushing has the oil grooves in both sides as well. Very beefy I must say.
Rod length is 6.098 like normal. Big end numbers are the same as the reg LS and the small end is a .945 pin. In the middle of the rod, it measures .605" wide. The beam between is tapered, so i cannot get a good measurement there unless you want an average.
PICS!!!!
![Name: SDC10622.jpg
Size: 192.6 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620545d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10622.jpg)
![Name: SDC10624.jpg
Size: 132.1 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620546d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10624.jpg)
![Name: SDC10625.jpg
Size: 51.6 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620547d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10625.jpg)
![Name: SDC10626.jpg
Size: 150.7 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620548d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10626.jpg)
![](http://i637.photobucket.com/albums/uu96/jginter/SDC10627.jpg)
![Name: SDC10628.jpg
Size: 137.7 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620549d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10628.jpg)
Notice on the bushing there is a notch on one side and not the other. Interesting.
![Name: SDC10629.jpg
Size: 77.1 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620550d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10629.jpg)
PICS!!!!
![Name: SDC10630.jpg
Size: 61.2 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620551d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10630.jpg)
As you can tell, these photos are not the most professional, but it gets the job done. I now have pics of the LS9 rod VS the LS7 rod.
The strange part is, this particular LS7 rod weighs (with bolts installed) 466g, so that is more than the LS9 rod. The LS9 rod is a tad shorter though. All that undercutting on the small end and the bushing for nothing I guess. Ha. Also the LS9 rod has a full round bushing with no oil grooves. Strange. Also found some more casting numbers on the sides of both rods.
Props to Joseph for getting me this LS7 rod just in time for the photoshoot!
LS7
![Name: SDC10637.jpg
Size: 64.9 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620537d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10637.jpg)
(I use the scale to weight parts not paraphernalia....anymore)
LS9
![Name: SDC10636.jpg
Size: 56.9 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620539d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10636.jpg)
![Name: SDC10639.jpg
Size: 80.7 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620540d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10639.jpg)
LS7 left LS9 right
![Name: SDC10635.jpg
Size: 84.1 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620541d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10635.jpg)
![Name: SDC10634.jpg
Size: 100.5 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620542d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10634.jpg)
![Name: SDC10633.jpg
Size: 127.3 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620543d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10633.jpg)
LS7
![Name: SDC10631.jpg
Size: 93.1 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620538d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10631.jpg)
LS9
LS7 left LS9 right
![Name: SDC10632.jpg
Size: 143.0 KB](https://ls1tech.com/forums/attachments/generation-iv-internal-engine/620544d1501358293-lsa-pistons-vs-ls9-piston-facts-pics-sdc10632.jpg)
#34
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
None the less thanks for the photos and info on the differences and weights of the items
#36
Also both crate engines from GMPP come with the Flywheels and clutches already on the engine in the crate. So its really a killer deal. They do not come with accy drive like pictured in the GMPP pics though, which does upset some people. But they do now offer the accy drive kits separate for them, so it makes it more cost effective.
In comparison between the 2, the LSA runs about 15K and we normally have 1 on hand, and the LS9 runs 23k and we are normally sold out. They are both sold in the same trim style, and really I think the LSA is the better deal of the 2. Both have the same GMPP warranty as well.
#37
Awsome read! Now I understand that the lsx 376 pistons are coming available. Are they not the same as the LSA pistons but just forged. I also understand that pretty quick the flat top 376 lsx piston will be available and that should fit the ls3. Any information on that?
#38
also can a ls2 bushed rod be used with the lsa pistons? i may have missed it in an earlier post if so.
plus any updates about the 4.065(+) bore pistons from gm
#40
Being a professional industrial diesl mechanic, it is impressive to see how similar these pisto/rod assemblies are to diesel engines.
The pin mounting, the oiling holes, etc ate almost identical to the diesel engines.
Of couurse I have never seen a titanium rod in a diesel, as a piece of 10 pound iron usually suffices as a diesel's connecting rod.
