single bolt cam help
Old Feb 24, 2010 | 03:24 PM
3timeracin's Avatar
Default single bolt cam help
I have a 2008 GMC 5.3 ho LM33 with a single bolt cam, I want to upgrade but all the cams I see are listed as ls1, ls2 and ls6 in all the catalogs. What do I need to look for so I get the correct cam. Thanks
Old Feb 24, 2010 | 03:27 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You can either order the cam on a single bolt core (Comp has them in stock and doesn't charge any extra for them), or you could run a 3 bolt gear by purchasing the GM 4X 3 bolt cam gear and 3 cam bolts.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 24, 2010 | 04:03 PM
3timeracin's Avatar
I have looked for the gear everywhere ? I must be looking in th wrong places ? Do you have them ? I have several cams already as I used to work at West Tech I just need the gear then. thanks
Old Feb 24, 2010 | 04:13 PM
4x 3-bolt cam gear = 12586481
ARP Cam Bolt Kit = 134-1003
We have both in stock and ready to ship!
__________________
Old Feb 24, 2010 | 04:26 PM
3timeracin's Avatar
I have the 3 ARP bolt set already I just need the gear I cant find it on your site ? what application do I look under ?
Old Feb 24, 2010 | 07:58 PM
summitss/rsls3's Avatar
is this what i need to run the G6x3 cam in my ls3?
Old Feb 25, 2010 | 09:19 AM
It's not on the site, but if you call we can get you setup!
Yes, if the cam is a 3 bolt core, you need the gear and bolts to run it in your LS3.
__________________
Old Feb 26, 2010 | 06:39 AM
thanks, guess thas more parts for my list.
