2007 L92 Escalade no DOD?
Old Mar 11, 2010 | 02:07 PM
68Problemchild's Avatar
Default 2007 L92 Escalade no DOD?
This is a junk yard motor I am working on. Just need to confirm the Escalades did not have DOD.
On memory, the valley cover did have the "maze" on the inside.
Anyway to determine/confirm no DOD without pullling intake and valley cover off?
Thank you!
Old Mar 11, 2010 | 07:30 PM
dimetweaker's Avatar
if you had the vehicle vin you could check with the dealer for options I guess, otherwise, I think you have to pull the valley cover. It only takes a minute though!
Old Mar 11, 2010 | 07:52 PM
Hotrod406's Avatar
Thank you!
You can see the maze with the intake still installed. Maze=DOD
Old Mar 11, 2010 | 08:15 PM
SweetS10V8's Avatar
Yup, dont need to pull anything. Just look at the valley cover. Maze= AFM Smooth= No AFM
Old Mar 11, 2010 | 08:45 PM
Patrick G's Avatar
LS1 Tech Administrator
For what it's worth, all '07 Escalades were non-DOD. If your's has the maze, it must not have come from an Escalade. Believe it or not, some salvage operators are not completely honest.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 11, 2010 | 09:10 PM
Hotrod406's Avatar
When did Escalades start DOD?
Old Mar 11, 2010 | 09:49 PM
Patrick G's Avatar
Never had it.
__________________
Old Mar 11, 2010 | 11:46 PM
Originally Posted by Patrick G
Never had it.
escalades never had AFM at all? ****... I have been doing the run around game with the dealer because they are trying to sell me a AFM oil pump for an escalade and say they cant get anything else. WTF?
Old Mar 12, 2010 | 12:39 AM
DIRTYBIRDWS6's Avatar
That is not correct, they did have AFM in 07. I'm a GM tech and just double checked in GM service info.
Old Mar 12, 2010 | 12:44 AM
maybe you can help with my VVT oil pump issue... Whats going to happen if I run a VVT oil pump from a NON DOD L92 in the motor after installing a conventional cam?
Old Mar 12, 2010 | 09:53 AM
Patrick G's Avatar
I've owned one and tuned several. Don't have AFM. They have VVT, but they do not have DOD/AFM. Sure they have a table for AFM, but if you check it out, you will see it's turned off.
__________________
Old Mar 12, 2010 | 10:18 AM
Default Computer turn off DOD
So does a maze = DOD absolutely? I read various opinions both ways. Some indicated DOD equipment was present but not activated because the sound was awful and some trucks could not accommodate a muffler to silence it.
Also, any way to simply turn it off on the computer?
Lastly, I have read that simply putting a smooth valley cover on fixes the problem. Theory being, you may have high oil pressure (30% more) from the specific DOD oil pump, but without the maze valley cover the additional pressure will not seal/engage the DOD and shut the cylinders down. I would love to hear if this is true.
Old Mar 12, 2010 | 12:58 PM
MDM@SDPC's Avatar
LS1TECH & TRUCKS Sponsor
Default Dod/afm
Actually, the 2007 L92 engines had a first and second design. The first design had AFM and the second design, for whatever reason, did NOT have AFM. If this particular engine has the "waffle" cover it is a first design engine and would have AFM. You will need to use the "second" design valley cover(smooth) with the "o-rings" to seal the oil passages in the valley. You will also need to change the 8 AFM lifters and 2 lifter guides for 8 NON-AFM lifters pt#17121490 and 2 NON-AFM lifter guides pt#12595365. You can use the same timing components except for the cam gear(actuator on VVT models) which would need to be changed to a pt#12576407(3 bolt gear). You will also need to swap the VVT front cover for the LS2/LS3 front cover pt#12600325. You will also need to change the oil pump if you take the AFM and VVT off this engine. The stock L92 AFM/DOD oil pump is NOT a viable option. The LS6 oil pump pt#12586665 is the pump we use in this application. The AFM/DOD can be turned off using HP Tuners, EFI live, etc. I hope this helps!
Old Mar 12, 2010 | 10:26 PM
SweetS10V8's Avatar
Yes....
Old Mar 12, 2010 | 10:45 PM
redsap05's Avatar
the 2010 is the first year of the escalde and denali to have dod
Old Mar 13, 2010 | 02:39 PM
Default Confused
Still seems to be some serious disagreement here.
I want to keep VVT for what its worth, but NOT the DOD. The place I bought it from swears its from an Escalade.
Old Mar 13, 2010 | 02:44 PM
cam's Avatar
cam
Yes so it will have VVT and shouldnt have DOD so your set. Run the VVT and get a VVT friendly cam and go. Thats what Im doing also
Old Mar 13, 2010 | 05:20 PM
SweetS10V8's Avatar
VVT is AWESOME!!!! It sickens me to see so many people chuck it in the trash!
I hope it all works out for you.
Old Mar 15, 2010 | 04:26 PM
Red face Thread update
OK, I feel pretty stupid here but when I took off the valley cover it has a maze UNDER it, eg the backside.
The maze everyone is referring to in on TOP of the valley cover. Also, the guy I bought the motor from clued me in. There is a big black wiring harness plug on the firewall side of the valley plate for the DOD sensors. Its independent from the plug for the oil pressure. No sensor no DOD. No maze on top = no DOD.
Thanks again for all your help. Did I mention I was a newbie?
