how far down mill 243's
Old Mar 12, 2010 | 12:07 AM
max1's Avatar
Default how far down mill 243's
i have a couple of ported 243's laying around..
i wanted to know how far down can i mill to get to 58-59 CC, w/out having PVC problems , or having problems with the intake.
my cam has a .581 lift on a 112lsa, that's the highest lift im going with.
Old Mar 12, 2010 | 12:31 AM
AES Racing's Avatar
lift isn't the issue, PTVC issues are mainly with opening of the intake valve.
If you have a early opening intake or late closing exhaust, associated with overlap, thats where you find issues.
with 59cc 243 heads largest cam i've seen run is speed inc. SI5v2 231/237
Old Mar 14, 2010 | 09:41 PM
redsap05's Avatar
I am wondering this to. Except everyone I have talked to has said that if you mill them you have to keep you duration 230 or below for got ptv. Hope someone can shine a little light on this. Thanks
Old Mar 19, 2010 | 12:22 AM
max1's Avatar
im gonna be running 228R cam..and dont plan to go any higher on cam- might mill a bit more 2 boost up more compression
Old Mar 19, 2010 | 02:24 AM
tillery's Avatar
Mine are milled .046 but I have a -4cc piston. running a MS3 till my new trick flows just showed up. Now its a Vidicator(240/244).
Old Mar 22, 2010 | 07:42 PM
redgto4u's Avatar
I was wondering this too....is the patriot 243 the way to go for a higher cr with 243 heads and a larger cam?
Old Mar 23, 2010 | 12:36 AM
brian_rs/ss's Avatar
i would like to know also. i have a set of stock 243's i want to mill (along with other things). my cam is 224/224 .581/.581 so i don't think i'll clearance issues. i just want a good CR to run on 93 octane. i was thinking .030-.035?
Old Apr 19, 2010 | 08:46 PM
Engine_HP's Avatar
any problems with the intake fitment ?
Old Apr 22, 2010 | 03:21 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
If the heads have stock valves in them you should be have enough room with a 59cc chamber and the 228R. I always recommend checking though, especially on a setup like this where the heads have been milled a decent amount.
Old Apr 22, 2010 | 03:24 PM
1nasty86's Avatar
Turd Gen Guy
i have a set on my 5.3 shaved them 0.030 and have a 0.040 head gasket with a 224/228 .581/.588 and have no clearance issues... course i know 5.3's pistons are dished and ls1's are flat. hope this helps
Old Apr 22, 2010 | 04:24 PM
Nitroused383's Avatar
I run 243's that have been milled .020" (62cc) with a .051" GM MLS gasket. With a 224 intake lobe I only have .068" piston to valve clearance. Check it your self, don't believe everything you read on the internet.
Old Apr 24, 2010 | 07:34 AM
1lejohn's Avatar
I ran the GM cnc 243's that were milled .060 with stock MLS head gaskets. The pistons were flat tops and a MS3 cam. I had plenty of clearence.
Old Apr 27, 2010 | 10:34 PM
SOMbitch's Avatar
Old Apr 28, 2010 | 07:13 AM
chrs1313's Avatar
Originally Posted by SOMbitch
my exact thoughts too...bullshit...
someone needs to learn how to measure...plenty of clearance too, not even tight...
measure yourself guys with a SOLID roller...
some measurements I have taken
stock 241 heads unmilled, stock mls gasket 230/230 111+2
intake .086 exhaust ~.120
TFS 215 57.5cc chambers, .040 gasket, 239/243 110+3
intake -.020 exhaust .040
Old May 9, 2010 | 12:33 AM
max1's Avatar
what was ur CR?
did u have any intake alligment issues?>
