PCV and crankcase pressure.........experts come in
intake capped off - breather catch can going to the valve cover and valley cover.
intake to catch can - catch can to valley - valve cover capped off.
intake to catch can - catch can to valley - valve cover to a fresh air source to the air bridge.
I also read, and think...the stock LS1 set up had the hose going to the air filter, but if its before the MAF, isnt that unmettered air?
Seems to let out smoke everytime I rail on it. Besides a vac pump, what method can be used to create more positive pressure to suck that oil back down?
Thoughts?
by both valve you mean run them as the dirty side, or tied into the hose for the intake?
intake to catch can - catch can to valley - valve cover to a fresh air source to the air bridge after the MAF...
Thoughts?
If your engine is not very tight then you have no use for the "P", it will just suck a ton of oil out of your crankcase and thats not good. The normal pull of vacuum is WAY TOO MUCH if your engine is not tight. It will need to be adjusted like I did for mine. My system works great and almost stopped all my fuel burn issue.
Here's mine below. I simply pull vacuum from the passenger side valve cover, and have a breather on the rear of the drivers side valve cover. So I pull fresh air in, it crosses the entire engine and it gets pulled out of the passengers side valve cover. BUT....I have the vacuum strength dialed down using that T-valve and metering screw. I capped the valley cover port...I personally think pulling vacuum from there (on a bow-by engine) pulls way too much oil from the crankcase.
do you have a valve in that tube from the intake to the valve?
It will work good for you. I put a clear hose on there to see iany oil gets sucked in like that and I saw none. Hooked up normally to the valley cover port, it sucks up alot constantly. What I did was the fix for an engine wih aot of blow-by.
And yes....you can see the metal torques bolt I put in that T-valve to open up the vacuum as much as I want, or totally close it off if I want.
The suction from the intake is just too much I think, so I leave it at a setting thats about 1/3 strength of factory stock suction. It pulls plenty but not too much where I suck oil from my crankcase. Theres no need for a catch can, just turn down the suction and its perfect. I never have any moisture in my crankcase.
