58X Crank in 6 liter block w/ older style cam sensor
New to this forum thing and to the LS world in general....I have a question for all of you LS gurus out there. I decided to jump into the 21st century and build an LS engine for my '66 LeMans. Started out with a 6 liter truck engine core, bored the block .030 over, got a callies stroker crank (4.000 stroke), compstar rods, diamond forged pistons, comp cams big ***** thumpr cam, new lifters, 3/8 pushrods, oversized valves, victor jr carbureted intake, MSD box, 11:1 compression, roller rockers, etc.... basically trying to do everything right with good quality parts.
Anyway, here is my situation: this block originally came with a 24x tooth reluctor wheel on the crank. When we ordered the new stroker crank, all the company said they had were the 58 tooth reluctor wheels (apparently the 24 tooth reluctor wheels haven't been made in a number of years and the replacement supply has just about run out). The MSD controller I purchased is for the newer generation engine with 58x reluctor wheel.
Question is will this engine run properly with the older style cam sensor (mounted in the back of the block) with the newer style 58x reluctor wheel and newer style MSD ignition box (pn 6012)? I haven't tried to hook anything up yet, just trying to make sure I have my ducks in a row.
Any information/advice you guys can give me would be very much appreciated!
Call MSD tech with that question. I believe they will want the newer upper timing gear that matches the 58X crank wheel for everything to work together. The timing gear you need will have multiple breaks instead of the half moon looking one that was used with 24X cranks.
Kurt
Kurt
LS1Tech Sponsor
