prep block for a stroker?
Old May 5, 2010 | 08:12 PM
TransWS6Am's Avatar
Default prep block for a stroker?
i just got a complete l92 pullout and i wanna put a stroker kit in it. My question is is it necessary to bore or hone the block b4 i install the stroker kit. i know ls3/l92 bore size is 4.065 so if i just get 4.065 pistons with the stroker kit and put them in will i be good? exactly what prep work if any should be done b4 putting the new pistons in if they are the same size as stock.
Old May 5, 2010 | 10:33 PM
AES Racing's Avatar
This thread would be a good read
https://ls1tech.com/forums/generatio...rate-dyno.html
The main journal on factory new LS block are tight and need to be honed to obtain correct bearing clearance.
The bores do not need to be cut (bored) provided not corroded or damaged; torque plate hone will ensure they're straight, have correct wall finish, and will have proper piston/wall clearance. If not honed, you risk oil consumption, detonation leading to low compression.
When we bolt on the torque plate the bores are typically out .001-.003" (on a new LS2 or LS3 block).
Also need to grind a few spots to clear the rods with stroker crank.
Old May 5, 2010 | 11:06 PM
TransWS6Am's Avatar
wow that is a great build, i just learned alot. yeah i think im gonna have a reputable shop to it now. lol. kinda sux i was looking forward to doin it myself.
Old May 5, 2010 | 11:09 PM
TransWS6Am's Avatar
im moving to michigan next month anyone know i good shop to put my stroker together?
Old May 5, 2010 | 11:34 PM
AES Racing's Avatar
I'll have to think about that one <sarcasm>
https://ls1tech.com/forums/sponsor-v...g-engines.html
Old May 5, 2010 | 11:35 PM
TransWS6Am's Avatar
lol, whats a ruff estimate for you to install my stroker kit.
Old May 5, 2010 | 11:49 PM
LLC's Avatar
LLC
A funny man!
Everyone knows the best in Michigan is Kurt Urban.
Old May 5, 2010 | 11:59 PM
AES Racing's Avatar
Originally Posted by LLC
A funny man!
We're not the only shop who knows how to build an LS1, not far from Michigan either.
