434 Lsx lifting heads
Thanks in advance.
O-ringing would be a good choice at that boost level but there have been many guys who have run that boost level without o-ringing. What is your tune like? Where is your timing?
I have heard Cometic's have a hard time sealing if the surfaces are not milled to a certain smoothness.
Ls2formula had some issues with his TFS 245's cracking, maybe you are having the same issue.
Thanks in advance.
What kind of power it made?
We used a 5 axis CNC to deck the block from the first o-ring setup. Our 1st o-ring was supposed to be .020 depth, it took .030 to get it completely out since some of the groove had inconsistent depths.
I've been there done that and am speaking from experience.
I can hone a block with a drill in my garage, don't make it the best way to do it.
1632rwhp, atleast 1800 engine hp, take atleast 140lbs/min of airflow to get that number which is out
of the efficiency.
http://www.turbobygarrett.com/turbob...0-7,8,9,10.pdf
a 434ci engine can spool 2 88mm turbochargers.
Can you run a reducer?
I guess the next thing your gonna tell me is that you can't put sleeves in a block without a 5-axis CNC because you can't cut the register close enough. I might as well just get out of doing engine work all together until I get a 5-axis. I'll never put another O-ring groove in now. BTW, I am on my fourth or so cutter.....but it can't be done. The key is to know what you are doing, as with anything. How did everybody do it before, the less than 25% in the trade who own a 5 axis CNC, when they didn't have a 5 axis CNC? O-ringing heads and blocks must be NEW technology.....LS1Tech technology..... maybe
