Crazy coolant leak that fix it self?
i have a fresh LS2 thats stock cubes. im running GM MLS 5 layer head gaskets. TFS 225 heads and ARP head studs.
So this is what happen. i just got the engine back in the car this week. im filling it with water just in case of leaks. good thing too, i look under the car and its leaking water WTF. so i track it down and its coming from a head stud WTF. that cant be unless i have a bad head gasket or a crack head right?
so im im like f@#$ it i finish all of the other samll thing i had to do to start the car. ran the car for 25 mins AND IT STOPED LEAKING. Oh i did put a pressure check on the coolant system to make sue it was the stud,
now i did wash one gasket that i drop on the ground with brake clean and i saw a coating comig off the gasket from the inner layers
so has this happen to any of you? i dont want to pull the head its a pain with the turbos. im going to put some GM coolant sealing pellets in the system as well
thanks for any help you can give my car has been down for 9mo now i want to drive it
Brake clean is powerful stuff so its probably just the sealer washed off. If it takes up with the tablets so long as your compression is tight and theres no issues with the tune or the way it runs I think I'd run it. Turbo engines get torn down often enough so trying to limit that as long as possible would be my approach.
