Milling ls7 c6z head...Changing pushrods ?
This forum has been very useful for my c6 z06 build-up ! I now want to mill head, is 0.030'' ok ? What compression should I expect to have and should I change the pushrods ?
Thanks DOHC
http://www.angelfire.com/fl/procrastination/motor.html
If your running stock head gaskets, you could go thinner there. SDPC told me for every .009 thinner it raises the comp ratio about .25 . .030 on ls7 heads should be ok.
