Who's the cam guy to help me spec this...?
Old Jun 13, 2010 | 02:00 PM
general23cmp's Avatar
Default Who's the cam guy to help me spec this...?
408 iron block
forged rotating assy with 9.3:1 CR
PRC L92 ported heads, LS3 intake with siemen's 80# injs
Twin 6265 turbos at 15psi max (probably 12psi most of time)
Beefed-up 700r4 with ~3000rpm stall
9" Ford rear with 3.73 gears and 28" tire
1971 Chevelle weight
street manners with 93 octane, but would like aggressive idle sound
max rpm ~6500
Want a pro's recommendation...was looking at the new lingenfelter GT9 myself, but a custom grind is likely.
Old Jun 13, 2010 | 02:55 PM
mike c.'s Avatar
i think pat g could do a good job here. I had three l92 cams already and his cam made the most power and has no bucking like the others. Give him a shout.
Old Jun 13, 2010 | 03:21 PM
garygnu's Avatar
PATRICK-G is the person you want to talk to .
Old Jun 13, 2010 | 04:39 PM
This Patrick G must be like the Yoda of cams...
Does he just provide specs or does he grind them, too?
Old Jun 13, 2010 | 05:33 PM
03 snake's Avatar
Pat will give you a very detailed spec sheet which you can forward to your chosen camshaft supplier.
I love my Pat G /EPS cam they set up for me. Geoff and Pat are both great to work with $.02.
Good luck with your project.
Old Jun 13, 2010 | 06:31 PM
Thanks. I know we don't discuss specific pricing, but is it reasonably priced to have him spec one, considering a custom grind cam will be is the $400-500 range at least?
Old Jun 13, 2010 | 06:47 PM
Found everything I needed on his website....very reasonable.
Old Jun 13, 2010 | 10:22 PM
Unaffliated Racing's Avatar
$400-$500!!!!! I'll do any grind for $359
Old Jun 14, 2010 | 12:39 PM
Well, I already have my cam specs from Pat G, and boy am i glad I went that route. The numbers are unlike what I had planned on my own, so it was good I requested help.
Fast service at a reasonable price. Thanks!
Old Jun 14, 2010 | 01:49 PM
cam's Avatar
cam
PatG and EPS are making magic right now. Getting a cheap cam is easy.... Getting a cam that does exactly what you want, how you want, and better than just about everyone else is difficult and therefore costs a little more.
Get what you pay for.
I have a PatG spec EPS grind VVT cam just about ready to drop in FINALLY. I've had it for 3 months but work has been insane and no time to do the work and I dont farm out builds to ANYONE anymore. Another saying I like...
If you want something done right? Do it yourself
