What to build?
Old Jun 19, 2010 | 03:05 PM
Ls1ChevyII1963's Avatar
Default What to build?
Just looking for some opinions on my motor build.
I've got a set of stock ls7 heads with titanium valves and I'm trying to decide on what shortblock to build.
Car is a 99 z28 street car with 4500 stall weighs about 3250.
I'd like a low 10 sec car n/a.
Old Jun 19, 2010 | 05:33 PM
odarabla's Avatar
Man, with those heads the skys the limit!! What's your budget like?
Old Jun 19, 2010 | 05:49 PM
Was thinking around 6K but might be able to do a little more if I need to.
Old Jun 19, 2010 | 06:05 PM
odarabla's Avatar
With those heads I would build a big cubed motor, something 427ci or more. For $6000.00 you can get an LSX block and build a big bore 454ci or if you wana stay with the light weight alluminum blocks you can buy a LS7 block and build a 434ci or just buy a LS3 block and build a small bore 427ci. Anyone of these engines would make consideral h.p. and would be a beast in a car!
The cheapest route out of the bunch would be going with a New LS3 block and building a stroker 427ci motor. The problem is going to be that the LS7 heads are built for a 4.125 bore and I believe the biggest bore size you can get out of a LS3 is a 4.080 bore. I would say you would have to run a dome piston to bump the comression up.
Old Jun 19, 2010 | 06:35 PM
Yeah thats really what I'm really trying to decide do I want a light weight ls7 block or do I want to go all out with the lsx block. I'd like to this car to stay n/a.
Old Jun 19, 2010 | 06:41 PM
CETAWS6's Avatar
Now that u mentioned it, I'm getting a build of a LS3 427 exactly just like mast motorsports but SDPC is doing the build.
Old Jun 19, 2010 | 07:05 PM
odarabla's Avatar
I would recommend just getting a LS2-LS3 based stroker motor 402-427ci. For the budget you have, sell those heads and get a set of ported LS3/L76 heads. They would be a better match for those engines. I love the LS7 heads but unless you are building a motor with a 4.125 bore size I would think you would be hurting yourself more using them than using one of the others mentioned. You can contact Shane over at Thunder Racing and have him quote you a price on a built 402ci motor. Here's the link.
http://www.thunderracing.com/
Or you can go with one from Texas Speed. They even sell on ebay.
Again if you need anything else hit me up man.
http://cgi.ebay.com/ebaymotors/TSP-4...Q5fAccessories
Old Jun 20, 2010 | 12:28 PM
How much are these ls7 heads worth?
Old Jun 20, 2010 | 06:05 PM
filmjay's Avatar
ERL Superdeck 440.
Old Jun 20, 2010 | 11:48 PM
supermouse4's Avatar
I'm thinking 415ci with an 6.0L iron block with a horsepower range of 550 to 600. With my new job, I don't have enough time to build a complete motor from scratch, perhaps I might just buy a short block.
Old Jun 21, 2010 | 10:18 AM
ERL Performance's Avatar
We've got sleeved 454 fully assembled, balanced and blueprinted short block for 5000.00 with you supplying the core block. Give us a call and we would be happy to help you out.
Old Jun 21, 2010 | 06:40 PM
I've been trying to get ahold of other sponsors on here and haven't gotten anywhere. I appreciate the info and I'll be giving yall a call sometime this week.
Old Jun 21, 2010 | 06:50 PM
filmjay's Avatar
How much is added to the price w/out core?
I'd like to keep my #'s matching shortblock...just in case.
Old Jun 21, 2010 | 09:28 PM
I'd build a 434ci motor with an LSX block.
Old Jun 22, 2010 | 11:44 PM
delphigto's Avatar
I went with erl. ls2 block also saves you a 130 lbs on the front of the car where you dont want it. http://www.erlperformance.com/gm-ls-...e-short-blocks
