Major engine problem === or is it ?
Old Jul 9, 2010 | 06:55 PM
thomaswatk's Avatar
Default Major engine problem === or is it ?
I have an LS2 out of a '06 GTO transplanted in a classic car. The problem has gotten so bad, the car is undriveable. It started out while I was on a trip. I thought I was running out of gas. Stopped a few minutes, fired it up, drove another 500mi. Happened again. Drove about 300mi., happened again. Stopped at a local shop and was told I needed a crank sensor. Replaced it. After that, it ran great for about 1000 mi. except that when I stopped for gas or for few minute break, then started the car, it acted like it was in vapor lock. Shuddering, missing, etc.. When I got to about 30-35 mph, it cleared up and seemed to run fine. This happened every time I stopped. The problem seemed to happen only when the car was at operating temperture. Now it has progressed to happening all the time. Went to another shop and they replaced the crank sensor again, saying that code was popping up. Worked for about 2miles, then started again. Today I had to restart the car 4 times just to get it into a bay at a friends body shop. It spits and sputters, backfires, and now quits. It will restart ok, but it won't take any gas, or isn't getting any gas. Since the friends shop is about 65 miles from me, I'm hoping not to have to get it "rolled back" to where I live. What could cause this ? Any suggestions will be welcome. I'm going to look for a mechanic that is local to where the car is, but it's a small town, and I may not have any luck, that's why I hoping to get some suggestions here. Sorry to be so long, but this is a real delimna for me.
Last edited by thomaswatk; Jul 10, 2010 at 06:35 AM. Reason: mistaken about the MAS
Old Jul 9, 2010 | 08:00 PM
nysbadmk8's Avatar
Sounds like a wiring issue. Exactly what code is popping up?
Old Jul 9, 2010 | 09:14 PM
sergo's Avatar
yes, please list all codes?
Old Jul 10, 2010 | 06:40 AM
thomaswatk's Avatar
The mechanic didn't tell me which code or codes came up. I guess I'll have to wait until I find someone else to check it out. I had hoped that my description of the problem would generate some thought. Maybe the same thing had happened to someone else and they could relay what fixed it. Guess I'll have to wait until next week when I can have it towed somewhere to see what the problem is.
Old Jul 10, 2010 | 07:39 AM
cookseyb's Avatar
Fuel Filter? It will do strange stuff if it's dirty...
Old Jul 10, 2010 | 10:17 AM
thomaswatk's Avatar
Replaced the fuel filter and fuel pump. That was my first thought. I even took the wire going to the fuel pump off and jumped it stright from the battery. Didn't help. I hope it will be something simple, something I can replace without a great deal of labor expense. Thanks for the suggestion.
Old Jul 10, 2010 | 10:37 AM
lt1pwr1's Avatar
Did the shops check for shorted wire to the crank sensor? I would think they would but that is assuming you told them it was replaced recently and the problem still persisted.
