JPR Cam Installation Tool
Old Jul 10, 2010 | 07:49 AM
JG853's Avatar
Default JPR Cam Installation Tool
Hello -
Does anyone have one of these I can buy or rent from you?
Installing cam in LS7.
Please let me know.
Joel
262-893-4317
Old Jul 10, 2010 | 08:02 AM
Billy1987's Avatar
pm sent
Old Jul 10, 2010 | 12:09 PM
Damian's Avatar
LSX Mechanic
Don't waste your money and go guy 2 steel 5/16" rods from Home Depot. Cut them to fit, and they do the same exact thing for about 1/20th of the price.
Old Jul 10, 2010 | 12:29 PM
ShevrolayZ28's Avatar
I've read many of your posts. You keep it real....thanks! ...just sayin.
Old Jul 10, 2010 | 01:05 PM
Damian's Avatar
LSX Mechanic
That's the only way I know how.
Thanks
Old Jul 10, 2010 | 03:44 PM
slt200mph's Avatar
Use your long water pump bolts they will work too and are even cheeper ..
Old Jul 11, 2010 | 04:44 PM
JG853's Avatar
thanks for all of your help guys. I really appreciate it.
JG853
Old Jul 11, 2010 | 06:05 PM
NVR_SPDS's Avatar
The JPR cam install tool is for holding the lifters up, while pulling the cam out.
Like was said though, just pick up some 5/16 steel rod, and use those. i want to say they should be a little over 20" each? Also, when i did mine, just so there were no issues, i rounded off the ends of each, so they couldnt scratch anyhthing in there.
Old Jul 12, 2010 | 06:18 AM
JG853's Avatar
Thanks - Should they be 20" in length or 24" in length (I have a LS7). Anyone know?
Thanks again for everyones help!
Old Jul 12, 2010 | 08:37 AM
slt200mph's Avatar
Ooops sorry...not familar with jpr or rpj or whatever tool .... I thought he was talking about that overpriced tool to bolt on the cam to install it ... I use metal tubing to hold up the lifers ... there is nothing in there you need to worry about scratching
Old Jul 12, 2010 | 08:47 AM
Damian's Avatar
LSX Mechanic
Buy both the rods, and set them next to your new cam. Cut each rod about 3 inches longer than the camshaft, and you're all set.
Old Jul 12, 2010 | 12:49 PM
JG853's Avatar
Thank you
Old Jul 12, 2010 | 09:40 PM
nick.celis's Avatar
+1. i bought 2 5/16ths rods, mine are 24" i went an inch over just to have about 4" stick out so i can grab. There is no point in buying that overpriced tool when those rods keep the lifters in place the same as that tool would
