lsx block question
And whats really ridiculous......they didn't even fix all the screw-ups after they switched manufacturers.
I just got a RHS Block and had everything checked. For the few hundered bucks it will pay off in the long run. I must say The deck, Main and cam bores were all dead on. I did however have the cam opened up to 60MM and the hone redone.
Best of luck with it.
The cam bores have been known to be tight and require a little honing to get them to proper size. If it would have been checked earlier, it could have been done while it was on the line hone and saved some time. Just chalk it up as a learning experience.
The most recent block delivered was perfect on the cam tunnel, not helping you I know.
Kurt
