ls6 heads on a lq4 with flat top pistons
First will 243's fit on a lq4 block with flat top pistons?
Second what kind of power would it make with a stock ls1 intake and 228 236@50 .624 .600 lift cam?
LS1Tech Premium Sponsor
Agreed, if they are flat-tops and your block is iron then you actually have an LQ9. And yes, the LS6 heads make a nice addition on top of that short-block and with the GM MLS gasket bump your compression up to 10.9:1 (same as the LS2's from the factory).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Does anyone know which head gaskets you are suppose to use? 6.0 LQ4 block with 853 LS1 heads.
I used LQ4 head gaskets, haven't fired the motor yet and one of the heads is leaking antifreeze. Should I have used LS1 head gaskets?
^^ 12498543
__________________
The graphie gaskets are less prone to leaking but you can just go to a dealership and get some stopleak tablets that GM uses. Have never personally done this but have heard of multiple people doing it after a head install and finding that it leaks.
If this is in front of a 6spd youre going to make very close to 400@ the wheels depending on intake.
__________________
Nice picture and very helpful in spreading the knowledge abut that casting! Thank you!
__________________
