So my 402 just quit!!?
Old Jul 21, 2010 | 01:24 PM
KRAZY K 2000 TA's Avatar
Default So my 402 just quit!!?
just did a nasty 1st 2nd 3rd gear burnout got up to speed about 50 mph,let off the gas and it stalled popped it into neutral started it back up while coasting checked oil pressure 55 psi ,water temp 174, put it back into gear chirped the tires a little bit and stalled no engine noises no leaking oil nothing? I it will not turn over at all, Motor acts locked up.?? I think its my transmission . any ideas.
Old Jul 21, 2010 | 01:53 PM
OUTLAWZ RACING's Avatar
Does the lights stay on when u attemp to start it?
Old Jul 21, 2010 | 02:25 PM
Gaunt's Avatar
Is your security light on?
Old Jul 21, 2010 | 02:44 PM
no security light you can hear the starter engage and lights dim
Old Jul 21, 2010 | 03:11 PM
Vexzer's Avatar
Does it crank with the clutch in?
Does the motor turn if you push the car while in 4th gear?
Come on you know this...
Old Jul 21, 2010 | 05:33 PM
SIK02SS's Avatar
Wouldn't explain why it shut down, but maybe part of startup: Did your clutch engagement switch come loose?
Old Jul 21, 2010 | 05:48 PM
nysbadmk8's Avatar
My guess...
You turned a lifter, wore it into the cam... Locked the cam up, and now the motor wont turn..
Old Jul 21, 2010 | 06:43 PM
BlownVette 2001's Avatar
Put the car in neutral and put a socket on the crank bolt and see if you can turn the motor over.
Also check for codes ?
Old Jul 21, 2010 | 08:24 PM
trans disconnected, it is the motor i cannot turn it over with a socket on the crank,pulled plugs all gray like it was detonating? had this timing table for five years exactly never detonated at all,pulled one head amd pistons show signs of detonation bad too?i will get pictures tomorrow night when we completly disassemble it,i noticed it was really using oil lately but it wasnt showing it on my plugs or leaking. this is my fault for not paying attention like i always did. SOO what compresion should i go up too?
Old Jul 21, 2010 | 08:28 PM
Irish350's Avatar
that really blows man.. keep us up to date.
what would cause a lifter to turn, over revving/float?
Old Jul 21, 2010 | 08:38 PM
lifter cannot turn its a solid roller motor with link bars
Endure-X™ Solid Roller Lifter from comp cam.
Old Jul 21, 2010 | 08:54 PM
sergo's Avatar
12:1 with bigger heads, intake and t/b
Old Jul 21, 2010 | 09:23 PM
Well if you were having detonation problems, I would not bump the compression any higher.
BTW, what was your current compression ? Seems odd to have these problems after 5 years of no problems. Did you have any codes, for bad O2 sensor, etc ... that could have changed your fuel mixture (AFR) ?
Hope the block is re-usable.
Old Jul 21, 2010 | 10:05 PM
nysbadmk8's Avatar
still voting on a lifter failure.. But extremely unlikely with those lifters
Old Jul 21, 2010 | 10:17 PM
frito1's Avatar
If you were using/burning oil, how much oil was in your intake? If your PCV was routed back to your intake, oil getting to the combustion chamber is a great way to start some uncontrollable detonation. Don't ask me how I know. I now have two oil catch cans... one has a breather on top.
Old Jul 21, 2010 | 10:25 PM
Irish350's Avatar
thats why im about to have a 402
Old Jul 21, 2010 | 10:52 PM
SIK02SS's Avatar
extreme over-revving. Like shifting from 3rd to 4th, but going into 2nd instead.
Old Jul 22, 2010 | 05:12 AM
did that on my stock motor, but i have a turbo 400 now. and yes i believe it was the oil in the intake because i was going to buy a new catch can today, alot of oil.
Old Jul 22, 2010 | 01:23 PM
SIK02SS's Avatar
this post is full of
and then extreme amounts of
Sorry man
Old Jul 22, 2010 | 01:49 PM
Whistler's Avatar
Sawzall and Welder Mod
Pull the oil filter and cut it open, see if it's full of glitter.
