Damaged heads are they worth it ?
Old Jul 28, 2010 | 08:57 PM
Quick99TransAm's Avatar
Default Damaged heads are they worth it ?
heads are of 2010 camaro with 2600 miles come assembled with rockers for 300 bucks for both.head dropped exhaust valve on 1 cylinder tell me what you think.
Attached Thumbnails Damaged heads are they worth it ?-l_5da600b483574abcbf40de7be94bedfe.jpg   Damaged heads are they worth it ?-l_b23791ba1b3e448cb3e5020963291944.jpg   Damaged heads are they worth it ?-l_94f5c3b5dc6f49eaa44295f45d213f17.jpg
Old Jul 29, 2010 | 03:36 AM
djsanchez2's Avatar
That can easily be fixed, question is how much is it gonna cost to be repaired vs. buying a new head?
Old Jul 29, 2010 | 04:24 AM
LS1MCSS's Avatar
Too much money, when you consider how cheap new L92 heads are.
Old Jul 29, 2010 | 07:09 AM
fuel's Avatar
wow that valve beat the **** out of the head......buy a new head and have peace of mind
Old Jul 29, 2010 | 09:42 AM
Fourman's Avatar
300 for the assembled pair is a steal. If I were you id buy them, one new bare casting and a pair of new valves and you're good to go for 600-ish total cost
May be able to find somebody to buy that damaged head off you too to use for porting practice or flycutting
Old Jul 29, 2010 | 09:56 AM
Tony Mamo @ AFR's Avatar
Flow Wizard
That head is beyond a reasonable repair....reasonable meaning you could expect good (reliable) service after it was fixed.
The quote above however I agree with 100%
-Tony
Old Jul 29, 2010 | 09:59 AM
02_ramair_ta's Avatar
smooth it out, re-cut the valve seats, pressure check the head.. and its all good as new.. any decent mechine shop can do all of that for you.
between small labor, and new valves, you might spend around 100.00, thats if you dont know the guy..
Old Jul 29, 2010 | 12:07 PM
Default heads
i can get a bare casting l92 head for 236
Old Jul 29, 2010 | 12:14 PM
AES Racing's Avatar
Chamber needs to be welded up. It would be couple hundred into that fix.
Old Jul 29, 2010 | 03:51 PM
supermouse4's Avatar
I'd go with a new head, instead of trying to fix the head. The new LS3 heads assembled are a great for the money.
Old Jul 29, 2010 | 04:45 PM
IHEARTLS1's Avatar
waste of time and money to fix these. if new heads were 1500 dollars then i'd say yes, but they are not.
Old Jul 29, 2010 | 07:00 PM
fuel's Avatar
damn that chamber looks like the elephant man.......
Old Jul 30, 2010 | 09:27 AM
Jimbo1367's Avatar
hey... even a "elephant man" needs "lovin" too
Old Jul 30, 2010 | 10:02 AM
LS1MCSS's Avatar
-Tony
Look very close at the first and third pictures, unless it's one hell of an optical illusion,that's two different heads.
Old Jul 30, 2010 | 10:29 AM
04BlackSilverado's Avatar
Look at the gasket residue left over on the end of the head mounting surface that looks like a "C", it is in each picture, they are the same head.
Look you'll see.
Old Aug 3, 2010 | 08:28 PM
ls6427blown's Avatar
thats way to much
Old Aug 3, 2010 | 08:43 PM
Irish350's Avatar
-Tony
IMO there are people you hear, people you take the advice of, and people you listen to. This guys all of em.
