Zero oil pressure 2010 Camaro
Old Aug 6, 2010 | 05:17 AM
Cruz Lo's Avatar
Exclamation Zero oil pressure 2010 Camaro
2010 Camaro M6. 12K miles Texas Speed cam installed about 6K miles ago.
Was driving.... Stopped for about 1 hour. Go out to start and no oil pressure at all! Gage reads 0 and engine started to rattle bad. No issues before at all.
Any ideas before I start to take it apart?
Thanks.
Old Aug 7, 2010 | 10:16 AM
S10xGN's Avatar
Check the dipstick?
Old Aug 7, 2010 | 04:01 PM
99SS-T's Avatar
Sounds like the beginning of a 2010 build!!! Congrats! lol
Old Aug 7, 2010 | 04:23 PM
Cruz Lo's Avatar
Check if the motor had oil??????? LOL.
I have the pump off now. I can see the pressure relief valve was jammed. Tight to move had to really pry it out. Only thing is it was jammed in the pressure position when I checked it. But it was none the less stuck. HARD.
Motor holds pressure when I put air to the oil inlet of the block. So must be the pump.
I will upgrade to a Melling std volume high pressure pump. Just have to find a dealer that has one.
Time for a LS2 chain too......
Old Aug 7, 2010 | 06:01 PM
99SS-T's Avatar
Good. Broken engines are no fun. Expecially new ones in new cars.
Were you thinkin about puttin it back to stock and taking it back to the dealer? Thank God they moved the oil pump to the front of the engine. I dread thinkin about dealing with the pump in my 98 jeep 5.9.
Time for a bigger bump stick neway. GL
Old Aug 7, 2010 | 08:17 PM
Steve1969LS1's Avatar
We replaced the injectors in ours.. fired it up and 0 pressure on the gauge.. turned out the wire from the sender at the back of the intake was pinched.
So the first thing I would do is check the sender and the wire to see if it came unplugged.
This is why I like a mech gauge somewhere on the engine..
Old Aug 7, 2010 | 08:18 PM
Guess I should have read this first. lol
Moroso also has a real nice pump.
Old Aug 7, 2010 | 09:19 PM
Mike@ZMS's Avatar
I have 4 Melling 10296 hi volume pumps in stock.
I can sell you one for $139 shipped to your door.
http://www.zenithmotorsports.com/ls1...il-pump-1.aspx
PM me if your interested and I will give you the coupon code to adjust the price and shipping costs.
Old Aug 9, 2010 | 07:07 AM
vettenuts's Avatar
I would think the timing chain is fine and should be the latest one since the car is a 2010.
Old Aug 12, 2010 | 02:51 PM
Tainted's Avatar
why? LS3 setup is way better anyhow...
