what aftermarket balancer to use on an ls7 crank?
ATI makes a replacement that will fit that, not sure how light it is. The one problem with that damper is you can only run a two ring weight if you still need the ac belt. They can put the 3 ring on if you ditch the AC pulley, this is best for high power engines.
Kurt
Kurt
what is the down side of a 2 ring weight?
