LS7 dry sump pan/pump on LS1
Yes, you can run an LS7 dry sump on an LS1/2/6 or any other GENIII/IV block.
Here is what I think you will need... assuming you will stick with existing tuning setup:
1) Plug your existing dip stick hole in the block
2) LS7 pan and windage tray (and adaptors for aftermarket oil lines)
3) Custom oil tank and lines
4) LS7 crank (or an aftermarket crank with correct snout length in stroke of your choice when/if they become available)
5) 24x reluctor wheel installed on crank
6) LS7 crank timing chain sprocket
7) Early style (1X) LS2 cam sprocket and compatible chain
8) LS7 oil pump
9) LS7 front cover with sensor and LS2 style adaptor harness
10) LS7 Harmonic balancer or custom equivalant that does not yet exist.
Note that the LS7 harmonic balancer only lines up with C5 and C6 accessory drives. All other drives require either custom brackets or a custom balancer built specifically to counter the longer LS7 snout offset.
I may be missing a few details but I think that about covers it...
Bill
I image Crower or Callies can make the crank with whatever snout you need. And ATI would have a balancer.
Just to add to stuff Bill Reid posted above (in case someone is searching), the balancer will also line up with CTS-V accessory drives...they're the same distance off the front of the block that the C5/C6 drives are. It's the route I'm taking because as far as I can tell, it's the most compact accessory drive, the alternator is down low like an f-body, the power steering pump is on the drivers side head, everything is just really snug into the block side to side and also pulled just as close to the front of the block as a vette setup. I have a big engine bay, but I have to fit 2 turbo's and a dry sump tank and all my plumbing in, so I went with the accessory drive that worked best for me...and luckily makes it pretty easy to use the LS7 dry sump oiling system too.
. I'm up in the air with putting it behind that headlight, or between the passenger wheel well and the cowl. I'm not using GM's tank. It's a good part and I'm sure it functions really well, but it won't fit where I want it to. Kurt
1. Does anyone know which of the two lines comming out of the block is suction and or discharge?
Thanks Mike
I honestly want to know if I can buy the parts from GM: oil pump, oil pan and timing chain cover, and put them on my LS6/383... The Tank and plumbing are a moog point..
I have read 20/30 posting about this…but no one has put the LS1/6/2/3 crank down and told me the LS7 crank is longer .500, .100, .050...nothing but a bunch of guy say NOTHING.. This is LS1 Tech, not LS1 BS right??? Somebody PLEASE give me some hard evidence about this…
Kurt
