BMW E46-LS3 - help with GMPP ECU
Sorry to repost but I dont think I my old post title was getting the right attention.
Ive just completed an LS3 transplant into my e46 BMW and the engine shut off after two sessions.
what is the LED light in the fusebox? Basically my engine cranks but it doenst start, the LED light in the fusebox doensnt turn on. No current in the ECU, so the relays wont turn on. No current in the pump or the ignition.
Cant fault code it because the ECU wont read because there is no power.
It stated for two days but during shakedown gave up on me.
I noticed that I was running super rich as well, Is my aftermarket 280LPH fuel pump to strong for the engine since it doesnt have a fuel return?
I have the GMPP LS3 harness kit on it now. Looking for some help again.
how easy is it to tune this GMPP ECU?
here is my old thread if you want to see photos of the build.
https://ls1tech.com/forums/generatio...ls3-motor.html
Have seen this on GMPP harness kits before. E67 ECM was stone dead out of the box.
Do you have a fuel pressure regulator with a tank return?
GMPP ECM's are the same to tune as any regular GM ECM (mostly
) Have seen this on GMPP harness kits before. E67 ECM was stone dead out of the box.
)the engine has no return line.
whats a good software to get to tune the engine?
