VVT Cams
1) VVT-"friendly" lobes have compromises like slower ramp rates or lower lift, thereby putting VVT cams at a disadvantage
2) VVT-"advantaged" lobes are designed differently to take advantage of the VVT feature, thereby putting them further ahead than nonVVT lobes that have simply had VVT phasing enabled
Seems to me like the jury is out on whether we're talking 1 or 2. Maybe TSP can answer.
That being said, you take a VVT cam and install it straight up, its going to make X hp. Retard it, and you are going to loose power down low, and pick up power up top. Its engine 101. So, VVT or non VVT is irrelevant in that regard.
If there are limits on ramp acceleration, and lift, you can take that into account in the lobe slection and trade it for duration as an example.
But in a VVT ONLY application you can run whatever lobe you want
BTW its running now
Im just waiting on some parts now and then the tuning process begins so I should have some numbers for my set up soon.
In case anyone is wondering its a stock 07 L92 6.2L with an uported LS3 intake running the 87mm truck TB though 1.75" SW headers, 2.5" Y and a single 3" exhaust in front of a t56. Its a PatG spec'd custom grind EPS VVT street cam. Nothing crazy but hoping to make good numbers. I'll be posting results as soon as I have them
But regardless in the meantime Im going to push forward with the tune and get it more responsive as right now its a bit confused down low and seems to hunt for the correct timing ( assuming both cam and ign ) before it takes off. I can say this sucker has TON of torque.... A hella lot more than my TR224 LS1 ever had
My guess is having the comp phase limiter in there and still running stock timing on both cam and ign is messing it up so Im going to attempt to sort it even if I only have 4000 RPM to play with today.
Heres what I did to all three boards of VVT timing. Going to work though ign timing now
We are looking into a different cam for more power any ideas, we are new to the LS world. thanks for the help.
We are thinking of getting rid of the AFM/DOD
I have also read reports of low speed driveability sacrifices with the nonVVT 277LR, which the additional 2* advance in the VVT-2 might help with. What that article above points out is the piston-valve clearance with flat tops may be marginal withthe nonVVT cam and I'm sure it can only get worse with the added advance of the VVT-2: definitely check your PTV clearance if you install this cam (or any cam really).
Here is another article using the 277LR on a stroker: http://www.carcraft.com/techarticles...d/viewall.html
Another note, in the newer catalogs for single bolts cams, there is a 277LrR single bolt cam (146-458-11) which has more exhaust duration and slightly more exhaust lift for the rectangular port heads. The 277LR cam (54-458-11) was designed for cathedral port heads, though the difference is subtle.
Hopefully this helps others trying to make a camshaft choice.
I think you may be confusing ICL (intake centerline) with LSA (lobe separation angle). A 107*ICL is not out of the ordinary and the VVT will change it. For example, at 2* retard, the ICL will be 109*, matching the LSR277 cam. At 4* retard, the ICL would be 111*. That's the nice thing about VVT - you can change the cam's performance on the fly by modifying the timing of the valve events.
On another note, when you see something like "113+6", that means the LSA is 113 and the cam is advanced 6 degrees such that the ICL is 113 MINUS 6 = 107.
With VVT the VVT-2 cam can be 113+6, 113+5, 113+4, etc etc.
