VVT Cams
I'm curious if either company's lobes were designed with AFM/DOD in mind and if so what sort of compromises were made (if any) to that end. I'm also curious how the profiles vary in order to accomodate the VVT. Obviously the cams are ground with lower lifts that similar duration non-VVT grinds. I presume this is to prevent piston-valve interferance during VVT operation, but I also wonder if the ramp rates had to go down to prevent the VVT mechanism from losing control of timing.
Any info is appreciated. I don't want this thread to be a pissing match of VVT vs. non-VVT - I'm more interested in knowing what differences are incorporated into the lobe profiles.
Our testing, as was backed up by Comp Cams' testing, revealed/confirmed that those stock AFM lifters will have a significantly shorter life (some ending catastrophically) when run over that magic .295" lobe lift (.500" valve lift on a 1.7 rocker)!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
http://www.compcams.com/Technical/Ca.../pdf/page9.pdf
Also keep in mind tsp is the only vvt camshaft provider that includes the phaser table when you order a camshaft.
We engine dyno tested our camshafts at each rpm to create the best possible phaser tune.
Who wants a phaser camshaft that doesn't include a updated phaser tune?
Checkout our engine dyno vvt data I posted compared to other camshafts your considering. We have several options for afm/vvt or just vvt.
One of the camshafts even makes over 100 flywheel horsepower gains! That's what's going in our shop 2010 l99
. Afm lifters don't really like going past .500" lift.The vvt only camshafts are much closer to typical ls camshafts, but some vvt minded tweaks!
How do these VVT cams work in a turbo set up? Going to run a LY6/TC76 turbo. Would i want to run a VVT cam or go to normal LS style cam for my set up. It's NOT going to be a race car or weekend drag car. It's built to drive on the street with limit track days.
Once the tune "secrets" become more available you'll see a ton more VVT stuff happening. Its still kind of new and tricky which scares most people away.
If you want a cam that will fit your needs exactly get Patrick G to spec you one
Not to mention the fact that you actually recognize the phaser change GM did. Every other site has no idea what I'm talking about when I try to get the VVT cam on the 189 core.
He who cannot recall history is condemned to repeat it
Enjoy your carbs fellas LOL
I have decided to use the VVT so I am looking for tech info on my options for VVT cams. I PMed TSP and they would not share their cam specs (lift, duration, LSA) citing concern that their cam design would be stolen. It puts me in a tough spot as a customer because I have no way to judge their cam or compare it to offerings from other cam manufacturers. I will call to get more info from TSP tomorrow. At the very least it's good to see there will be more VVT cam options in the near future.
edit: oh and my LY6 does all of this on 87 octane... I doubt one point of compression (and another $8 at each fill up for premium) makes all that much of a difference.
The phaser limiter kits seem like they should have to account for this, but I've never seen a limiter kit for the new phaser yet.
There are always custom grinds available for those interested contact Patrick G ( im starting to feel like a broken record here ) He has some interesting options available for VVT applications that are a far cry from what the shelf cams offered are.
As far as using a bigger cam, I was referring to the diminishing returns that I saw in the GMHTP L92 article. It seems that with the cams that they used on the L92 (all comp products, different companies may yield different/better results?) you really reached a point of diminishing returns, but there was never a sacrifice at the low-end and you even saw gains at the low end. This indicated to me that they were reaching the limits of the untouched L92 head with the cams they were using. This leads me to believe that head porting might be necessary if you really want to maximize what a bigger VVT cam can do. Again, I'm not sure if using a cam from a company other than comp, on untouched L92 heads, would yield different results; I was just going on what I saw in the article.
But thank you for furthering the use of VVT though - you're doing a huge service for the LSx community.
I planned on a Patric G spec'd cam, but its nice to have another option with TSP. Having the VVT tables makes me lean towards TSP
Who knows what if fact or net rumors..
