VVT Cams
Old Oct 17, 2010 | 06:28 PM
Jimbo1367's Avatar
Originally Posted by Matt@Texas-Speed
I'll check into the valve drop info when I get back to the office on Monday!
thanks !
Old Oct 18, 2010 | 09:55 AM
cam's Avatar
cam
Anybody have any problems with the phasers granading with a aftermarket VVT/springs? I read somewhere that it happened to COMP CAMS when they first started the VVT cams. Something about too aggressive springs.
Who knows what if fact or net rumors..
I've read that too and posted about it as well. However I scour many boards keeping my eyes peeled for proof of phaser failures but I havent stumbled across one yet. That said I havent seen too many builds where anyones running big cams, dual springs and VVT yet either
Old Oct 18, 2010 | 12:18 PM
pillagenburn's Avatar
I don't see how it would be physically possible for the cam phaser to fail under any circumstances short of it simply being defective. The phaser isn't doing anything, physically, to the cam itself - it is simply operating as a valve to allow pressurized oil into the body of the cam to do its thing... GM is using basically the same VVT system as Toyota... and their system has been subjected to all kinds of high spring pressures and all manner of other stresses. Until we see an actual failure directly attributed to stiff springs, I'll call this one a myth.
Old Oct 18, 2010 | 12:28 PM
cam's Avatar
cam
Time will tell. I just prefer to err on the side of caution myself
Old Oct 18, 2010 | 12:50 PM
kballs's Avatar
Default VVT is taking over
I knew if I waited, the right people would pull through on this topic. A year ago, I bought a nice L92 donor for my 71 chevelle and asked around about VVT programming and cams. The most common answer was 'just throw all that stuff out and run ls3 parts in it'
I've been a tech at BMW for 6 years and know first hand that VVT or Vanos like the germans call it is not going away and it is the way everything will be going.
Same way people feared HEI distributors and swapped points dist. back in and tore off efi intakes from tpi engines and threw carbs on.
The car went for it's last drive of the year with the 500ci/tko600 combo and will be going back together with the L92/T56 setup or the tko. Trans hasn't been decided yet.
Old Oct 23, 2010 | 01:49 PM
Jimbo1367's Avatar
Still waiting.
Old Oct 23, 2010 | 02:06 PM
SweetS10V8's Avatar
Originally Posted by Coban
I would as well. From my reading, it looks like they also reduced the total movement from 52 to 42 crank degrees.
The phaser limiter kits seem like they should have to account for this, but I've never seen a limiter kit for the new phaser yet.
This made perfect sense, I googled it and Comp has done this. I just dont know if everyone knows about it yet.
Comp Cams #5456 (Early phaser)
http://www.byunspeed.com/product_inf...ducts_id=11722
Comp Cams #5460 (New phaser)
http://www.byunspeed.com/product_inf...ducts_id=13488
Old Oct 30, 2010 | 01:14 PM
Jimbo1367's Avatar
Any time to check on that MATT?
Old Nov 1, 2010 | 09:54 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Not yet, Jimbo I've been out sick and am way behind on everything currently. I'll try to get some info sooner than later.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 2, 2010 | 10:46 AM
Coban's Avatar
Thanks! I eventually stumbled onto a comp catalog update that specified this as well.
I tried to get a cam kit from TSP, but the part number off the phaser seems to be required in order to figure out which cam core/phaser is needed. For a daily driver, its just a difficult thing to do.
I really wonder how people are tuning without the cam phaser timing data that TSP provides with their custom cams. That's what originally got me interested, but it is a $100 premium....
Old Nov 2, 2010 | 11:01 AM
cam's Avatar
cam
The tuning "secrets" of VVT are seriously holding back development for a lot of guys. Now that I have three VVT equipped vehicles I will be playing around like mad with the tunes. Plus HPtuners only has VVT tuning in the current beta so support from their end is minimal as well.
Old Nov 2, 2010 | 05:59 PM
  #32
Jimbo1367's Avatar
I really wonder how people are tuning without the cam phaser timing data that TSP provides with their custom cams. ....
Thats the problem. I bet that these tuners(most) aren't touching any VVT tables. Just not trying to change the phasing at all, merely the timing and fuel.
I am leaning towards TSP if they ever do some LY6 R&D
Old Nov 3, 2010 | 11:12 AM
  #33
cam's Avatar
cam
A lot of tuners dont and it works but I've seen other people brag of how much power is left on the table under the curve if you optimize the VVT tables for power rather than fuel mileage which is what GM uses the VVT for primarily. So not tuning the VVT specifically for your set up is leaving a lot of performance on the table. It seems kind of senseless to me to run a hopped up VVT engine without getting the maximum benefits from it. So more info needed and we're working on it
Old Nov 4, 2010 | 04:59 PM
  #34
futureuser's Avatar
Default New Mast LY6 HO Cam
I just started a new thread on this subject. I spoke with Mast today and they just finished testing it with 509hp. It is uncompromised for DOD or 5.3 applications. I hope HP tuners and efi live can step up support it without using the Mast ecu.
Old Nov 5, 2010 | 05:07 PM
  #35
Jimbo1367's Avatar
Glad to hear. I am curious if its the same cam they call LY6HO/480HP. MAst probably just retuned it.
Old Nov 5, 2010 | 05:08 PM
  #36
Jimbo1367's Avatar
THIS>>>>>>> is eggs-actly what I am talking about.
Old Nov 5, 2010 | 07:23 PM
  #37
futureuser's Avatar
According to Mast, new cam. 509hp.
Old Nov 11, 2010 | 11:57 AM
  #38
-TheBandit-'s Avatar
I'll give Mast a call on this as well. I'm curious if it's the same as their L99/L92 "SS" cam (230/237 .588/.607 111LSA). The learning curve should eventually flatten out for VVT tuning now that the L99 is in so many Camaros. Give it some time. I would think if you asked nicely enough Mast or Comp would give you their dyno-developed cam timing table.
Old Nov 11, 2010 | 02:38 PM
  #39
I haven't been able to get ahold of Mast yet, but I was looking at their new 2011 catalog and they've listed a lot more and a lot more aggressive VVT cams than listed elsewhere on their site. See page 15: http://www.mastmotorsports.com/2010/...ts_Catalog.pdf
964-106 225/241 .614/.624 110LSA 113ICL
964-107 229/245 .617/.626 110LSA 114ICL
964-108 233/249 .621/.626 111LSA 115ICL
964-109 237/253 .624/.627 112LSA 116ICL
964-110 241/257 .626/.627 112LSA 116ICL
I'm curious about P-to-V clearance with these cams. The LSAs are a little tighter also.
Old Nov 11, 2010 | 02:43 PM
  #40
cam's Avatar
cam
Id like to try that one. I wonder what lobes they use?
