New products from Trick Flow
Confirm?
Yea, I payed attention to the intake valve being 2.1 and that they were good for a 4" bore min. I hoped the ex. was 1.60 but forgot to ask. Guess I was just too wound up by the intake side to remember to ask about the exhaust.
I will also have pricing for you guys here soon.
1) Assuming these will be at least 2k for a pair. what makes them so much better than the bargan basement oem l92 heads. Will they make more power
2) How the ptv clearance. If i mill them down to 65cc or use a thiner head gasket to keep my stock ls2 compression, how much would that hurt ptv with these heads.
I assume a stock ls3 intake will bolt right up which is great because they are on ebay for 275 bucks and make the same as fast, so thats a real savings there which is plus. I just whish they they would have made a smaller 62 cc version. Guess only time will tell. will be watching this one closely.
Will trick flow release them at a price point similar to the "CNC" LS heads or closer to the "As Cast" LS heads.
If they come in the price range of the "As Cast" ($1600 to 1900 depending on vendor and specials) and give Volume with Velocity (on the intake side) then it will be a hard head to beat.
to Redsap05
The Better valve angle should reduce PTV issues a little, but depending on the cam you use with the shaved head and a 2.1" valve you still may end up having to fly cut the pistons.
Sounds like the heads will be similar to the MAST's "Black Label" LS3 heads with a 12" valve angle. I just hope they come in at a lower price point!!!
Same size 2.10" valve that flows more air everywhere, therefore has a higher coefficient of discharge, which seems to be key for a street head.
12 degree valve angle rather than a 13.5 degree.
Uses lightweight LS7 rockers with 1.8 ratio, as opposed to heavy 1.7 aftermarket rockers required for the current 245's.
I'm betting they will have .030"-.040" more P to V than stock LS3 heads.
