New products from Trick Flow
Old Dec 10, 2010 | 10:17 AM
  #81
Paul Huizenga's Avatar
Originally Posted by 1fastxz
Was at PRI today
Didn't see any new heads?
Did I miss something?
Are these the droids you're looking for?
http://www.lsxtv.com/features/pri-co...w-specialties/
Old Dec 10, 2010 | 09:01 PM
  #82
1fastxz's Avatar
I wonder how I missed them..... Guess you had to be the right person to get to see this...
Old Dec 11, 2010 | 11:06 PM
  #83
The Baron's Avatar
hmm, I am kinda wondering, what kind of numbers tea will get out of the ls7 castings. if you can get similer numbers out of the intake as a set of stockers, and get the increased exhuast flow that t f is known to have over everyone else, they would be a welcome addition to my motor.
Old Jan 5, 2011 | 09:29 AM
  #84
pacebria's Avatar
UPDATES!
price and these are direct bolt on ls3 block?
Old Jan 5, 2011 | 06:30 PM
  #85
supermouse4's Avatar
Smile
Those look amazing, please give prices.
Old Jan 6, 2011 | 08:26 AM
  #86
TrickFlowTech's Avatar
LS1Tech Sponsor
Pricing will be available once the heads are in production somewhere at the beginning of March.
__________________
Old Jan 7, 2011 | 09:43 AM
  #87
ramairroughneck's Avatar
Originally Posted by TrickFlowTech
L92/LS3
255 cc
2.100 intake valve
69cc chambers
1.300 dual spring
4" minimum bore
Flow Numbers
Lift Intake Exhaust
.100 72 62
.200 159 117
.300 234 179
.400 292 224
.500 333 240
.600 357 252
LS7
255 cc
2.100 intake valve
69cc chambers
1.300 dual spring
4.125" minimum bore
Flow Numbers
Lift Intake Exhaust
.100 72 62
.200 159 117
.300 234 179
.400 292 224
.500 333 240
.600 357 252
I'm surprised that there isnt even a minimal difference in the flow given one head is for a 4" bore and one is for a 4.125 bore. Also, what are the .650 lift flow numbers?
Old Jan 7, 2011 | 10:12 AM
  #88
chriswtx's Avatar
what bore were the heads flowed on???
Old Jan 7, 2011 | 11:56 AM
  #89
Gregory's Avatar
Here's a question that is pretty straight up.
Are the heads available for 1/2" ARP head studs like what is available from ERL Performance?
Old Jan 7, 2011 | 06:25 PM
  #90
BigRich954RR's Avatar
are the ls7 Six bolt ?
Old Jan 8, 2011 | 09:22 AM
  #91
Stang's Bane's Avatar
Same port and same valve. Flow numbers have to be the same.
Old Jan 8, 2011 | 11:36 AM
  #92
Noted that. But why is one for a 4" bore. Obviuosly something is different. Does it have a smaller exhaust valve? I would think there would be a small difference of at least a few cfm if they are not totally identical.
Old Jan 11, 2011 | 07:39 AM
  #93
LS1Tech Sponsor
Sorry I have not been on to answer your questions. The heads are still going through our testing on our dynoes. When everything is done I will come back on with full details. Things are always subject to change during testing if we see something we do not like.
__________________
Old Feb 5, 2011 | 07:57 AM
  #94
LS6's Avatar
LS6
Talking
Any news
Old Feb 9, 2011 | 11:52 PM
  #95
earmuffs's Avatar
everyone always posts flow numbers at lifts. But how are velocities measured and why does no one test these?
Old Feb 10, 2011 | 06:52 PM
  #96
odarabla's Avatar
Originally Posted by cam
Look at his post count. Mighty informed for such a "newbie"
Looks like you also have a lot to offer this site!! Your post count is also rather low for the amount of time you've been here. Oh and BTW you are wrong about this site being $$$$ driven. The proof is in the pudding as Mr. Tooley has so kindly pointed out!!
Old Feb 10, 2011 | 09:31 PM
  #97
Brian Tooley Racing's Avatar
Yes, all of the LS3 and LS7 castings are going to be 6 bolt.
Drilling the bolt holes to 17/32" for the 1/2" head studs and be performed on any LS head for a small fee.
The LS3 is designed for a smaller bore, the exhaust valve is moved in .050" from the cylinder wall compared to stock LS7 and has a .010" smalller valve than stock LS7.
Old Mar 3, 2011 | 09:03 PM
  #98
sillysspeed's Avatar
Must be close?
Old Mar 22, 2011 | 09:33 PM
  #99
DietCoke's Avatar
More LS3 vaporware. Up for info
Old Mar 22, 2011 | 10:14 PM
  #100
Devilish34's Avatar
hmmmm
