Cam Question
We have a 02 Z28 M6 and my friend has a Comp Cam from a 6.0 LS2 Goat. Question is will it work in a LS1 and what mods need to be made, if any?
Spec's 238/240 112 lsa .605/.609 lift
LS1TECH & Trucks Sponsor
Yes the cam will work no problem in your car. You will need the appropriate valve springs and some hardened pushrods, along with a gasket kit to install it. Depending on miles some guys change out oil pumps and timing chains as well. Let us know what you need and we can get you the parts ASAP!
