Upping compression on stock LS3
Old Nov 22, 2010 | 11:33 AM
billyjo's Avatar
Default Upping compression on stock LS3
I have a 2010 Corvette LS3 car with about 2000 miles on it. I was thinking about milling the heads and installing thinner head gaskets to up the compression. My goal would be better mileage and slightly more power. Is it worth doing and what are the downsides?
Bill
Old Nov 22, 2010 | 07:23 PM
severous01's Avatar
milling wouldnt be worth the investment. you can do a head/cam swap. get a custom cam and get head from a lq9 or lq4...a truck engine...as they have less cc, 5 less but it's less to begin with.
and you can mill them further. but, they're the same bolt pattern, spacing and can use the tall manifold and the short manifold. mill them too far and the head ports will be too close and you'll have a hard time popping the intake on. other than that, you wont have a problem swapping truck heads onto the lsx block.
Old Nov 22, 2010 | 07:26 PM
ChucksZ06's Avatar
I do not think it would be worth it by itself. You might gain 10 hp. I would do cleanup porting on the heads and put a small cam in it. A stock c6 z06 cam would probably work well if you are on a budget and want to keep it sounding stock. It is easy to get into knock problems when you get the compression above 11/1 with small cams.
Old Nov 23, 2010 | 10:02 AM
87silverbullet's Avatar
Bill
You wouldn't get either by upping the compression. Just get a tune and a small cam just like Chucksz06 said and you will get your power and fuel economy.
WTF are you talking about? The heads from an lq9 or lq4 are 72cc and the ls3 heads are 70 cc. If he changed to the cathedral port head then he would have to get different rockers since his ls3 has offset rockers, then he would have to change the intake. All of that is not cost effective and most likely a power loss instead of a gain.
Old Nov 23, 2010 | 07:36 PM
billyjo's Avatar
Thanks guys, I'm not sure I'm ready to do a tune and cam swap yet. Definately not ready for that major surgery and voiding my warranty. I've only had it a couple of months. I thought if I could get a few more HP and better mileage I would do it since I can do it all myself and I don't think anyone would know.
Old Nov 23, 2010 | 09:40 PM
severous01's Avatar
sorry....it's only been about a year since i posted on here. guess i got my numbers mixed up. still....milling isnt worth it. be much better off with a cam or rockers.
if you wanna go through all the trouble of taking the heads off...have them sent out and ported....while they're out, install a cam and get a tune on the pcm.
Old Nov 24, 2010 | 09:31 PM
redsap05's Avatar
Ls3 heads have crappy piston to valve clearence. If you mill them you wont be about run any cam bigger than 224 duration on the intake side and even that would be pushing it.
Old Nov 26, 2010 | 09:18 AM
Yes, but those heads don't need much cam to make them run. They make good power with medium sized cams. I agreed with you on the milling though, its not worth it.
Old Nov 28, 2010 | 11:42 AM
Jimbo1367's Avatar
Start with a tune.
Old Nov 29, 2010 | 03:05 PM
396D1SS's Avatar
I am milled .020 with a 230 duration intake runs fine
