My first home build LS2 404ci
what kind of motor are you building ?
My motor is good
i have made best so far 10.85@130 NA
and 10.1@143 on save 200 shots
this is on 3470lbs race weight, T56 3.42 gears on 26 slicks
we don´t have any dynos here in Iceland, just HPT and the mountain roads
winter mods are:
GZ vacuum pump (i´m getting blow by like i knew i set the rings that loose) updating to Callaway honker Air intake
and 100mm MAF
28" slicks
and i´m going Auto too , I´m starting breaking driveline parts
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
built 4l60e to start whith
hoping to get better NA ET and then hit the 9´s on 200 jet and then i´m gona jet it up, maby 300-350 just gona see how all goes, work my way up
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
thanks and good luck
Baezi
I'll be putting together an LS2 402 same heads and cam as you. It's gonna get choked out a little with my stock intake but I'll be upgrading that soon enough. Also tuning myself with HPtuners. Will be spraying a 200 shot. Full weight car for the most part at about 3600lbs, but still lighter than most GTO's. T-56 trans and street tires. This is my daily driver, But I do have a tendency to beat on it once in a while haha. Thanks for the info maybe I can pick your brain a little when it comes time for tuning if you don't mind?
no prob
and good luck
Baezi
