PRC LS7 Small Bore Cylinder Heads Nears Production! 390cfm on a LS3 Bore!!
#161
#162
LS1Tech Premium Sponsor
Jon and I were here all day Friday, and anybody who called got all the information we have. What information did you want that you didn't get?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
#163
I actually spoke to you last week ( not on friday it was earlier in the week )and you ( unless there are two matts there ) told me that you had no info on these heads yet and that there would be posts on the boards when there was some avail... Im Not jumping on you guys but I had credit card in hand ready to order.
#164
If you called before we had information, yes, you would have been told that. We had all the information, including firm pricing, as of Thursday afternoon.
__________________
#167
It will be a month before i need them anyway. So no biggie.
im thinking these will be my choice when the rubber hits the road.
Consdiering offaxis' sig...this looks like a good comparo to do
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#172
Jim
#173
Any flow data on these heads?
Also is there any info on any of the cars with the 427`s that got the first run of these heads?
Ive bought everything except my current cam from you guys and I know If I was given access to the first run of these heads there would be dyno and track numbers already posted. Just sayin
#175
Placing an order with Scoggin Dickey today for the LS3 stroker...hopefully when i get it there will be someone with LS7 small bores ready ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Any ideas on chamber size? or did i miss that in the thread..
#176
The first small run of castings are gone. Guys can place an order any time you are ready. We should have more castings in another week or two.
6-bolt castings are standard
70cc Chambers out of the box (milling is available)
$2399.99 - Stainless Valves
$2699.99 - Hollow-stem Valves
$2999.99 - Titanium Valves
+ $50 for PRC EHT Springs
+$225 for PRC .700" Springs
Jon
Jon
#179
IIRC.......... intake port was only 4 or 5 cc more than stock LS3
