408 good enough to hold 1000hp+ setup?
If this is your goal on the FI route I would suggest you talk to a reputable engine builder such as HKE, Virginia Speed, or KUP. They can spec and build the long block you would need to get to your goal. They have all built motors in 1000+ hp range many times over.
For your forced induction needs I would recommend a call to Josh at KYTP so a turbo and a kit can be selected to meet the hp goals or if you plan on going the supercharger route talk to Bob@Brutespeed he is our Procharger sponsor. Good luck with the build and I hope I have pointed you in the right direction somewhat.
I forgot who but a company in Texas built a 1050 HP Camaro with a 427 and a Magnacharger and Nitrous.
Not a track car or track machine. Im trying to make this feasible and save myself money and get some ideas from ppl who have reached this but maybe learn from what they couldve done different to save themselves money or parts they should've gone with. Just a thought if the 408 was possible. Im leaning towards just saving it up for a LSX block like a 440cid. I dont wanna be constantly changin my setup and goals all the time over the years. I just want to make it final this time around. I say screw it lets go with 1000hp. I want to get the big parts first then the small things like my turbo setup and engine. I have a N/A setup with a stock block now which im enjoying for the time being but its time to go big. Our 390 engine would be a good option, small changes with stroke leaves a thicker/stronger piston and crankshaft,
you can read more about it here.
https://ls1tech.com/forums/forced-in...rankshaft.html
Sure, use some Callies crank/rods and Wiseco, JE or Diamond pistons.
We better be talking about FI or some serious nitrous.
