what will my compression ratio be?
Old Dec 19, 2010 | 02:32 PM
Steve671's Avatar
Default what will my compression ratio be?
I'm trying to figure out if I can run this combo on California premium 91 octane gas.
If I were to take a set of stock LS3 heads and bolt them to this LS3 427 stroker shortblock: http://www.schwankeshortblocks.com/s...?i=1518&c=1086
with flat top -7cc pistons, and stock head gaskets, any idea of what the final compression ratio will be?
Thanks,
Steve
Old Dec 19, 2010 | 02:57 PM
ChucksZ06's Avatar
You should be fine. I am assuming you will be using a cam with more duration than stock?
Old Dec 19, 2010 | 08:09 PM
Steve671's Avatar
Yea, nothing too radical though. I want it to be very streetable.
Old Dec 19, 2010 | 11:00 PM
litle88's Avatar
This site should help you out, http://www.wallaceracing.com/Calculators.htm
Old Dec 19, 2010 | 11:54 PM
ramairws6's Avatar
Thanks,
Steve
Good god, have you not did any searching on these shortblocks?? Good luck...
Old Dec 20, 2010 | 12:21 PM
Steve671's Avatar
Spent half the day yesterday reading about stroker 416 and 427's. Found that some had problems with their 427's, but found that others have not. I planned on making some phone calls today thinking that these issues have been worked out since engine builders are offering them.
I would like to know what it is that you are talking about, maybe you could point me in the right direction?
Thanks,
Steve
Old Dec 20, 2010 | 12:37 PM
Steve671's Avatar
Thank you.
