LSX 479ci??
What would be the cost of such a short block or a long block with matching heads, WCCH, TSP or PI, fully assembled.
cheers
As far as the cost of a short block or long block, I think the block alone retails for about $5K.
I'm probably going with a 4.25" stroke (nothing crazy since this is for a road race motor) and in the process of trying to spec out rods. Rod size will most likely be around 6.4" and I am not having much luck in finding any reasonably priced quality rod. Any suggestions would be welcome.
Eagle has a 4.375" crank, 1.888" honda rod journal, 6.460" rod, 1.110" CH piston, nice setup for a strictly N/A engine.
We have one going on the dyno soon. 475ci.
You Could use 4.250" crank, 6.560" rod, 1.050-.060 CH piston
Having the piston in the hole .010" not a bad idea on large bore builds.
cheers
