View Poll Results: Which head would you suggest
Voters: 59. You may not vote on this poll
MAST 305cc LS7 Heads or GM LSX-LS7 head for a NA 427
IS there any useable info on this other than people just saying this or that? I'm curious if these 305 heads kill your low end to supply top end power or if it's a good increase across the board because it would only cost me like 500 to get my LSX LS7 heads ported and polished.
but most of these 305 cc heads are going on 427+ and most of them are top end street or race applications-
i would say with a big engine-good compression like 12.0+ the low down trq would be great
i know of 2 x 305 cc builds going on at the moment and they are not ready at all-
#32
the problem is this-not many sets of 305 cc heads out their-
#33
I have a LSX 454 crate motor with 11:1 compression GMPP LSX LS7 intake manifold 6061 elbow and 102NW TB so I have the need for a good flowing head up top but this is in a Trailblazer which is a tank on wheels so I don't want to lose my low end. If these heads on a 427+ engine still do good down low and make big top end power they would be worth it for me. Other wise I'll just port my LSX LS7 heads and call it a day and live with my top end how it is with more low end.
Cary
#34
there are a ton of 305 heads out inthe field running. They are not 305 cc. That is a series number. They just have a larger 2.250 valve than our 285, which is 280cc with a 2.200. They are 288 cc. They will not hurt low end at all. The cross sectional area is still reasonable. Nothing to worry about. good luck with your build.
Cary
Cary
#35
#37
Cary
Cary
• Designed for any new Gen IV short-block with 4.125" bore or larger.
• Uses a 2.250" intake valve and 1.600" exhaust valve
• Has a 305cc intake port
If Cary is rite, then above statement from Mast is wrong, and if not the 274 cc Mast heads indeed outflow the 305 cc cnc castings across the chart, even with much smaller intake port volume, when compared the two flow charts, side by side...
274 cc 305 cc
lift int exst int exst
.300 245 171 234 159
.400 307 212 304 200
.500 350 229 356 228
.600 379 245 379 243
.650 388 247 379 249
.700 395 249 388 352
#38
I realize that you have made your mind up to use one of the two cylinder heads mentioned in the poll.
For those who are undecided, there is another cylinder head they may wish to consider it they are buildinga big bore, large cubic inch LS motor. West Coast Cylinder Head's ALL PRO LSW-1 heads.
I don't know what the GM LSX LS7 heads flow. The Mast 305 cc LS heads and the WCCH ALL PRO LSW-1 heads flow as follows:
MAST 305cc LS7 ------------WCCH ALL PRO LSW-1 - 285 cc intake - 108 cc exhaust
Lift------Intake---Exhaust---------Intake---Exhaust
0.100 ---- 75 ------- 55 ------------ 75.2 -----54.3
0.200 --- 155 -------108 -----------154.7 ----109.1
0.300 --- 234 -------159 -----------242.2 ----162.1
0.400 --- 304 -------200 -----------309.0 ----212.8
0.500 --- 356 -------228 -----------354.8 ----240.9
0.550 --- 376.5 -----236 ---------------------------
0.600 --- 379 -------243 -----------382 ------254.7
0.650 --- 379 -------249 ---------------------------
0.700 --- 388 -------252 -----------403.3 ----261.0
0.750 --- 395 -------255 -----------410.2 ----262.4
0.800 --- 401.5 -----258 ---------------------------
0.900 --- 406 -------260 ---------------------------
1.000 --- 410 -------263 ---------------------------
Just some data so we can all make better, informed decisions.
