Cam help for LS3 418
My setup is as follows:
LS3 418
Trickflow 225s CNC ported
mild 236 cam
fast 90/90
moser 9" w/ 4.11s w/ detroit locker
fully build drag suspension
Keep in mind I do plan on spraying, and was told both of these cams work well with nitrous
http://www.guerragroup.com/camshaft_help.htm
Numbers in my sig are on a pretty rich tune with low total timing due to only 91 octane fuel available around here. SCR is 11.85 and DCR is right at 8.4.
I know if we lean it out to 12.9 AFR and kick the timing up to 28* or so and get some decent fuel for it, (or Torco) it will make around 560/500 to the tires. Needless to say, I'm very happy with my combo and I have Pete to thank for it working as well as it does. Good luck.
Jimbo
Jimbo
Jimbo
also what numbers are you puttin down with ur setup?
Thanks,
Shane
