stroke a 4.8l motor?
Old Mar 16, 2011 | 02:00 AM
clayp's Avatar
Default stroke a 4.8l motor?
I have an 01 Silverado with a tired 5.3l motor. I bought a 50k mile motor that was sold to me as a 2006 LM7 5.3l motor but in pulling off the oil pan I discovered it has a 482 crank which means it is a 4.8l motor. It is very, very clean and I was wondering if I could throw in a LS1/LM7 crank to make it a 5.3l with higher compression? Would it cause any valvetrain clearance problems if I use the 4.8l flattop pistons with the stock 06 706/852 heads?
Thanks
Old Mar 16, 2011 | 06:01 AM
denscor's Avatar
Old Mar 16, 2011 | 07:47 AM
clayp's Avatar
I think I put this in Gen IV instead of the Gen III section. Sorry
Old Mar 16, 2011 | 09:02 AM
KCS's Avatar
KCS
Moderator
I'm pretty sure the engine in your '01 Silverado is a Gen III, and the '06 engine is a Gen IV. That might make a difference when it comes time to swap the engine in.
Old Mar 16, 2011 | 10:03 AM
clayp's Avatar
does this mean the 06 4.8 has the different reluctor wheel? I see that the 6.2l does but cannot find any info on the 4.8
Old Mar 16, 2011 | 11:37 AM
bronx_peanut's Avatar
You could put the 5.3 crank in but you would also have to change the connecting rods since they are longer than the LS1/LM7 rods.
Old Mar 16, 2011 | 11:44 AM
KCS's Avatar
KCS
Moderator
Yeah, I'm pretty sure it does. Not to mention the cam sensor may be moved as well as the knock sensors.
Old Mar 16, 2011 | 05:32 PM
Bo185's Avatar
The 2006 motor is a regular Gen III motor 24x etc etc...
Yes, you have to remove the pistons and change the rods as well. You can reuse the pistons though. But I would balance everything.
You could sell it. And rebuild your 5.3L. Bore it to LS1 size and you have an iron block 5.7L. But I doubt you get any money out of the 4.8L as no one wants it.
So ou could bore the 4.8L and add the LS/5.3 crank and rods. As well as find a set of 243/799 and mill them alittle to make it higher CR. That would make nice power.
Old Mar 17, 2011 | 08:21 PM
clayp's Avatar
well I decided to sell it to a friend who is going to swap it into an old Dodge Powerwagon. I'll be on the lookout for an LS1 rotating assembly or a 6.0
Old Mar 18, 2011 | 09:01 AM
redhotwheel98's Avatar
my stock 4.8 has a set of 243 on it
Old Mar 18, 2011 | 02:38 PM
Bo185's Avatar
Correct. He said his was a 2006 motor. All the Gen III 4.8L and most the 5.3L had the 862 or 706 etc...
All the 2007-up Gen IV 4.8/5.3L motors come with the 243/799 heads. I have even seen a 2009 truck that even had a 799 on one side and a 243 on the other from GM.
Old Mar 18, 2011 | 05:04 PM
thats crazy, talk about scraping the barrel for parts
